[TX] TPI Engine harness 85-88
Old Jan 10, 2014 | 03:03 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Removed from a running 88 Iroc 350 MAF. Its Nice and clean, 1 plug cap broke off in the area of the starter wire loom and i can't remember what it was, its not the knock sensor plug ,it's there, the terminal cap missing is pointed with a round green grommet. Over at the brake booster the Red wire is cut going to the brake pedal switch. That's it! it's in nice condition and ready to install.
Complete all the way to the ECM plugs-No fan harness. Thank you
Looking to get $135 shipped in the lower 48 states usa
Paypal only
pp info mgd6806@gmail.com
Attached Thumbnails TPI Engine harness 85-88-tpi-harness-013.jpg   TPI Engine harness 85-88-tpi-harness-016.jpg   TPI Engine harness 85-88-tpi-harness-017.jpg
Old Jan 10, 2014 | 03:28 AM
mjdavis68's Avatar
Re: TPI Engine harness 85-88
TPI HARNESS 021.JPGTPI HARNESS 024.JPTPI HARNESS 022.JPGG
Attached Thumbnails TPI Engine harness 85-88-tpi-harness-021.jpg   TPI Engine harness 85-88-tpi-harness-024.jpg   TPI Engine harness 85-88-tpi-harness-022.jpg
Old Jan 10, 2014 | 03:30 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Secondary fan temp switch, It looks Exactly like the ks connecter but usually light grey in color.
Old Jan 10, 2014 | 03:32 AM
mjdavis68's Avatar
Attached Thumbnails TPI Engine harness 85-88-tpi-harness-023.jpg   TPI Engine harness 85-88-tpi-harness-019.jpg   TPI Engine harness 85-88-tpi-harness-016.jpg
Old Jan 10, 2014 | 03:33 AM
mjdavis68's Avatar
Cool thanks Brian
Old Jan 10, 2014 | 03:42 AM
Engine: Lb9
Transmission: M20
Np
http://delphi.com/connectors/product...esults&start=0
Old Jan 10, 2014 | 09:56 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You shouldn't say '85- '88 because if it came out of and '88, that is all it will fit.
Unless a lot of modification is done.
Old Jan 10, 2014 | 03:16 PM
Engine: Lb9
Transmission: M20
IIRC, if it has the ninth injector on the harness 87-88, if not it would be a 89. I think the newer style better relays like you have shown would be from a 88. Good deal, bump for a great tgo member
Old Jan 10, 2014 | 11:36 PM
mjdavis68's Avatar
Yea it has the 9th injector...
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
