Crane cams PN#1449331
New in box
Brand:Crane Cams
Manufacturer's Part Number:1449331
Part Type:Camshafts
Product Line:Crane Hydraulic Roller Camshafts
Summit Racing Part Number:CRN-1449331
UPC:021174033304
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:2,900-6,500
Intake Duration at 050 inch Lift:232
Exhaust Duration at 050 inch Lift:236
Duration at 050 inch Lift:232 int./236 exh.
Advertised Intake Duration:294
Advertised Exhaust Duration:298
Advertised Duration:294 int./298 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.600 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.600 in.
Valve Lift with Factory Rocker Arm Ratio:0.600 int./0.600 exh.
Lobe Separation (degrees):114
Camshaft Gear Attachment:3-bolt
Computer-Controlled Compatible:Yes
Grind Number:HR-232/353-2S1-14
325$ shipped
New in box
Brand:Crane Cams
Part Type:Camshafts
UPC:021174033304
325$ shipped
Up
