[TX] Lloyd Elliott Ported AFR 195's/1040's 60cc
Sad to say but I've had to scrap my build and sell off some of my parts. I have these heads for sale.
AFR 195cc heads part number 1040. They were run for about 2 hours previously by Anethes here from Thirdgen. I bought them from IrocZ30589 here who did not personally run these heads. They have been milled .035 by AFR to get the chambers down to 60cc. Springs are the AFR 8017's good to .600 lift. Valves are 2.05/1.60 that AFR uses. I took them to Lloyd Elliott who is one if the best hand porters out there. I've used him for SBC, LT1, LS1 stuff and have been very happy with his work. Look him up he knows what he's doing. They received a full port job on the intake and exhaust runners. Chambers were left alone as they did not need additional porting since AFR CNC's them. I had Lloyd flow them afterwards and these things are ridiculous. I have pics of the heads and the flow sheet but they are not coming through my email just yet. Flow number are
149/122 @ .200
208/171 @ .300
263/204 @ .400
298/226 @ .500
310/235 @ .600
314/239 @ .700
There is well over $2k in these heads. My price is $1600. I will post pics when they come through my email. Thanks guys.
Zach
149/122 @ .200
208/171 @ .300
263/204 @ .400
298/226 @ .500
310/235 @ .600
314/239 @ .700
Zach
Car: 91 camaro
Engine: LS3
Re: Lloyd Elliott Ported AFR 195's/1040's 60cc
what cam were you planning on running..these are bad ***, I'm interested only I have a Lloyd elliot cam 107 lsa 230 duration and 565 lift split profile making 365hp/360tq at wheels, did he recommend any specific cam when he did these heads for you?
I second the question, where are you located? I am starting a 383 build for my vette and would need a better spring but if shipping is reasonable or you are in distance than I can justify 1600.
These heads are back up for sale. My old man is putting his 383 LT1 in his car so these are for sale still. Cam I was going to run was a 226/234 .571/.562 112 LSA. The heads flow alot of air but the ports are not massive. Lloyd really knows how to make a smaller port flow alot of air.
Car: '84 Z 28 RIP, Red 87 Iroc
Engine: has 8 cylinders
Transmission: has a stick coming out of it
Axle/Gears: no more pegleg
are these heads for a gen1 sbc or gen2 vortec style
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
damnit that's some ridiculous flow indeed man! so were just fired up? may i ask what happened so that they were torn down again?
also what cc size are the ports after the porting job, do you have any figures for that? and maybe conditions for the flow job.. bore size?
they look so nice, wow.
Engine: LS1 / L03
any chance you could give him a quick call maybe to find those details out for me and others interested?
easier to do that from your point i guess ^^
thanks!
easier to do that from your point i guess ^^thanks!
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Probably around 200cc now? Don't know that I'd be that concerned. They flow like a 210cc head but with higher velocity.
Here is the deal. I bought them new from AFR. I had AFR mill them to 60cc because I was running the car naturally aspirated in my '79 Z28. I assembled the motor, fired it up, broke the motor in for about 15 minutes. I drove the car in and out of the shop during the summer. I sanded, did body work, and painted the car. That winter, I came upon a thirdgen formula locally that had zero rust, and was a decent roller. It had T-TOPS, which my Z28 didn't have. I called a buddy who had purchased a '74 camaro tha tneeded extensive body work and offered him my Z28. He wanted it as a roller, so I took the motor + trans out.
While the motor was on the stand that spring, I came upon a procharger on craigslist for very short money. Since my motor was high compression, I needed to get some 75cc heads to run the blower. I ordered some AFR 210 heads, and sold these heads on the forum.
Of course, my intake wouldn't cover the ports on the 210 heads so I had to get a 1206 intake, which then hit my hood because it was taller so I had to get a different elbow, and so on. What a nightmare that was.
So no bs, they have less than 2 hours of run time and not over 2,000 RPM. With the right cam, 500hp on a naturally aspirated 383 shouldn't be too hard.
-- Joe
-- Joe
Engine: LS1 / L03
Joe, thanks for the detailed comment for interested buyers
With the insane flow they present now, as you already put it, there will be absolutely no trouble producing (I'd even say at least) 500hp in a 383, if you stretch it a bit with the cam and powerband, maybe a 350 even
Probably need to upgrades springs for that tho.. hmmmm...
Probably need to upgrades springs for that tho.. hmmmm... Thread
