[TX] TPI and LT1 performance parts
Old Mar 29, 2014 | 09:36 PM
LT1Formula's Avatar
I have a handful of parts here guys, take a look.
Bosch 36lb injectors with a fresh clean. Have new spintle caps and O rings. $150.
Comp Cams pro magnum 1.6 NSA 7/16 stud roller rockers. These have less than 500 miles on them. $225.
85-88 TPI Lingenfelter 58mm throttle body with rare LPE top cover. Does not have the air intake adapter but I've seen people custom make their own. $150.
94-97 BBK 52mm Throttle body. Used but in good shape. $175.
Lloyd Elliott ported 94-97 LT1 intake manifold. Lloyd says his ported intakes will add 10-12 RWHP in the upper RPM range. Would be sweet to see this converted to work with an SBC motor. $200.
93-97 M6 F-body Griffin Radiator. Installed but never even filled up. $350.
93-02 UMI torque arm. Installed but car has not even moved. Part # 2202. $325.
Old Apr 4, 2014 | 06:35 PM
LT1Formula's Avatar
Re: TPI and LT1 performance parts
Bump.
Old Apr 11, 2014 | 03:01 AM
LT1Formula's Avatar
Good stuff here guys.
Old Apr 11, 2014 | 04:30 AM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
I want the axle cover
91' bird 305 TBI T-5, trick flow heads, 4.10 gears, full UMI setup, track times coming soon!
Old Apr 11, 2014 | 03:07 PM
LT1Formula's Avatar
I'm sorry man the cover has been sold already.
midge54
Jan 29, 2017 07:00 PM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
