[SC] vortech v2 s trim supercharger for lt1
this is a 4th gen fbody supercharger setup with a brand new v2 s trim head unit. the main stuff is there, and is most everything you need to get the blower mounted and will take care of the piping. you'll have to figure out the drain tap into the pan, and your oil feed from the block to the fitting on the blower.
these pulleys are sized to produce a good bit of boost. 7" crank, 2.75" upper. the pulleys have been "anti slip grooved". i am also including a 3" pulley in case you want to tone it down a bit.
$1800.
sorry for the sucky pics. i can get more if interested. the piping is still dirty, i never cleaned it.
$1800.
Terry Kennedy
Dec 14, 2000 01:41 PM
