2 clutch pedals, ss trans cooler lines, tpi ecu, tpi dist cover
Old Feb 10, 2015 | 05:13 PM
Casey Meyers's Avatar
Car: 86 Z28
Engine: 385 HSR
Transmission: T56 stage 2
Axle/Gears: Moser 9" 3.70 locker
I have 2 clutch pedal setups,
82-84 mechanical. Make offer.
85 with switches, t5 master from an 02 v6. $50
Stainless steel trans cooler lines with extra cooler added. $100
TPI distributor cover, has small blemish in rear. $25
TPI ECU Service #1227165 chip is AUM 0122. $50
Tach, fuel level, voltmeter gauges. A bit faded but worked when removed. $20
can ship everything
Attached Thumbnails 2 clutch pedals, ss trans cooler lines, tpi ecu, tpi dist cover-transcooler.jpg   2 clutch pedals, ss trans cooler lines, tpi ecu, tpi dist cover-tpi-cover.jpg   2 clutch pedals, ss trans cooler lines, tpi ecu, tpi dist cover-t5master.jpg   2 clutch pedals, ss trans cooler lines, tpi ecu, tpi dist cover-mechpedal.jpg   2 clutch pedals, ss trans cooler lines, tpi ecu, tpi dist cover-hydpedal.jpg
Old Feb 15, 2015 | 09:54 AM
Car: 86 Z28
Engine: 385 HSR
Re: 2 clutch pedals, ss trans cooler lines, tpi ecu, tpi dist cover
Will take best offers
Old Feb 19, 2015 | 06:16 AM
Car: 86 Z28
Engine: 385 HSR
hydraulic pedals are sold
Old Feb 28, 2015 | 08:27 AM
Car: 86 Z28
Engine: 385 HSR
bump
Old Dec 18, 2015 | 07:05 AM
xylorex's Avatar
Car: 1987 GMC 1500 4x4
Engine: 383 roller, MPFI ecu by FAST
Axle/Gears: 3.73 Eaton Trutrac 30 spline convsn
PM Sent --- Give me a shout Casey
Old Mar 2, 2016 | 10:46 AM
Car: 86 Z28
Engine: 385 HSR
gauges and ecu are gone, everything else is still sitting around. make an offer
Old Mar 2, 2016 | 11:07 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Is the distributor cover plastic or aluminum?
Old Mar 14, 2016 | 01:03 PM
Car: 86 Z28
Engine: 385 HSR
plastic
1992 Trans Am
May 10, 2023 07:19 PM
beachrodder
Aug 25, 2015 08:05 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
