[Sold] Auburn limited slip for 10-bolt rear- $150
Old Jun 5, 2015 | 07:31 PM
Damon's Avatar
I took this Auburn limited slip out of the rear end in my G-body Malibu when I upgraded from the stock rear.
It's low mileage (probably less than 6000 street miles) and in excellent condition. I will GUARANTEE the condition. Clutches have almost no wear, ditto the spider and side gears. This is almost "like new". Side bearings still installed (their races are marked left/right to match) and are likewise in excellent condition.
This unit is for 3.08 and numerically lower gears, but can be used with higher ratio gears with the use of an inexpensive ring gear spacer or aftermarket "thick ring gear" sets designed to bolt into a numerically lower carriers.
These units are $400 new. I'm asking $150 for mine.
NOTE FOR 3rd GEN F-BODY USE: This unit is for 26 spline axle 10-bolts. That means the 10-bolt in your 3rd Gen F-body up through about 1989. Later 10-bolt rears used bigger 28 spline axles which WILL NOT WORK WITH THIS UNIT.
I'm right on the PA/DE line not far from I-95. Text or call: 215-519-4939.
Old Jun 8, 2015 | 04:01 PM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
Re: Auburn limited slip for 10-bolt rear- $150
ugh! if this were a 3 series unit i would have bought it in a heart beat!! good luck with the sale!
jrdturbo
Mar 31, 2016 02:58 PM
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
racereese
Oct 3, 2015 03:46 PM
