Accel DFI Gen 6 74022-A
Subscribe
Apr 5, 2016 | 02:46 PM
Price drop to $290 OBO
Selling a very complete Accel DFI Gen 6 engine management system. Was working properly when upgraded to Gen 7. Some of the harness wires were shortened and tucked into the loom to clean things up, for example knock and O2 sensor connections. Everything seems to be labeled well. Includes the following items:
DFI ECM batch fire part# 74022-A
Engine harness
Fuel injector harness which plugs into main
Calibration interface cable for laptop (old school serial port)
Cockpit A/F ratio controller, allows on the fly adjustment for idle and WOT
Calmap software version 6.0 and 6.32 provided via digital transfer, also latest version on floppy disk
User's guide
Museum quality laptop with a good old fashioned serial port that will work right out of the box but getting data in and out of the computer is a challenge without using floppy disks. There are usb to serial adapters out there that can be used however newer laptops might require some tweaking to get them to work.
Not seeing a lot of these on ebay and elsewhere so not sure how best to price it, I'll adjust as I go. How about $320 or best offer?
Accel DFI Gen 6 74022-A-img_20160405_104125.jpg   Accel DFI Gen 6 74022-A-img_20160405_104209.jpg   Accel DFI Gen 6 74022-A-img_20160405_104234.jpg   Accel DFI Gen 6 74022-A-img_20160405_104436.jpg   Accel DFI Gen 6 74022-A-img_20160405_104458.jpg
Accel DFI Gen 6 74022-A-img_20160405_104555.jpg   Accel DFI Gen 6 74022-A-img_20160405_104719.jpg
Apr 16, 2016 | 10:28 AM
Re: Accel DFI Gen 6 74022-A
bump
Apr 17, 2016 | 10:30 PM
does this work with boost and low -z injectors?
Apr 18, 2016 | 08:15 AM
Does work with boost you just need to get the right Map sensor that covers your manifold pressure range. I'm fairly certain it won't do low impedance but there's a separate box that accel sold which you could put between ECU and injectors to do that. I saw it on ebay a week ago but it's gone now. I found a link that talks a little bit about low impedance:
http://autofuelcontrol.com/acceldfi-...3i-74045-accel
Apr 18, 2016 | 01:31 PM
probably just a resitor pack not a big deal i can source my own if i cant come up with high-z injectors
im on lunch break from work atm but when i get home tonight ill pm ya an offer on iit would be nice to try out a system other then megasquirt on one of my builds for once
May 26, 2016 | 06:02 PM
Is this still available?
May 26, 2016 | 10:03 PM
Sorry it's sold
Subscribe
