[PA] Trick flow 490 hp top end kit for SBC ( will separate)
Trick Flow 490hp/ 440 ft. lbs top end kit. Part # k314-490-440. Includes (2) Aluminum heads ( 195 cc intake runners, 72 cc CNC combustion chambers, 2.02/1.60 valves) flat tappet hydraulic cam. roller rockers, double roller timing set, push rods, lifters, ARP head bolts, head hardware and all gaskets. $1500 firm
cam specs: adv. duration 308/316?
lift .510/.518
intake. duration @ 0.50 = 246
exhaust duration @ 0.50= 254
lobe separation 112
rpm range 3500-6700
$1500 firm for whole kit
Will break up kit into following packages:
Package #1
Heads :
part# TFS-30400013-CNC
72 cc combustion chambers
exhaust port ( d-port)
angle plugs
max. lift 0.600 in
outside dia of outer spring 1.460
Heads only $1350 ( cost $1500 new)
package #2
Cam/ lifters, cam button, cam locking plate, double roller timing chain set, pushrods,
cam/ lifter kit part # tfs-k31401002 (cost new $184.97)
chromoly (4130) pushrods. part # TFS-21407850 : 5/16" , 7.850" long x 0.080" wall ( for guide plates) ( cost new $99.97)
Trick flow SBC Billet timing set(double roller) true roller, billet steel sprockets part # TFS-31478500 ( cost new $ 69.97)
cam button part# SUM- G001 (cost new $3.97)
cam locking plate part # SUM -G1792 ( cost new)
total for package #2 ( cost new $361.97)
asking $325
package #3
Trick Flow Roller rocker arms (SBC) 1.5 ratio. 3/8" stud part # TFS-31400510 ( cost new 289.97) asking $250
package #4
Trick Flow Premium engine gasket kit
part# TFS-31400915 ( cost new $119.97)
asking $100
package #5
ARP hex heads bolts part # 134-3601
( cost new $ 86.39) Asking $70
Located in Hatboro,Pa
lift .510/.518
lobe separation 112
rpm range 3500-6700
Package #1
Heads :
angle plugs
max. lift 0.600 in
package #2
asking $325
package #3
package #4
asking $100
package #5
89irocz355
26
Sep 12, 2016 01:28 PM
