[VT] PARTING OUT 88 IROC Z -WILL SHIP MOST PARTS
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Have the following parts for sale from 88 TPI camaro
Mass airflow sensor-50 shipped
Camaro talight harness from 88-$25
Trans am tailight harness from 86-$25
88 camaro headlight harness-$30
Cruis control harness (engine bay with actuator)-$25
88 tpi 5 spd wiring harness(from firewall connector to c207 connector)75
A/C compressor-50 shipped
Alternator-105 amp-40 shipped
V6 t5 14 spline input 3.50 1st gear-$100
5spd console shift plate with great shift boot-$65 shipped usa
Clutch hydraulics,master,slave,line and reservoir assembly(new slave)-60 shipped
Fuel tank with sending unit and new fuel pump for tpi-$175
Tpi airbox-upper and lower-$50
Gauge cluster plastic lense-$10
3.23 posi drum rear axle-$125
LF fender-$65
Front grille-fog light type-$30
Rear bumper-$65
Doors-drivers 125, passenger dent, $75
Rear hatch with glass-$45
Upper center console-45
Lower console-45
Hvac/radio bezel-$15
Front parking lights-$40 shipped
Fender marker lights with clips-20 shipped
Tailights-65 pair
Sail panels-$25 pair
Visors-$25 pair
Driveshaft steel-$25
Drivers underdash/fuse panel -20
Throttle cable for tpi-25 shipped
Dome light with harness and cover-22 shipped
Tailight/trunk harness uncut-$40 shipped
Speedo gear housing in transmission-$20 shipped
Torque arm mount-$35 shipped
Factory t5 shifter-35 shipped
Front nose emblem-$20 shipped
Many other parts, will try to ship
Pm or 802.310.2878
Located in vermont
LF fender-$65
Rear bumper-$65
Lower console-45
Tailights-65 pair
Visors-$25 pair
Pm or 802.310.2878
Located in vermont
Re: 88 camaro iroc z tpi drivetrain,pedals,etc parts LOCAL PICKUP ONLY!
Will try to ship!!!
Car: 1985 T/a, 1988 Formula
Engine: LB9 and LO3
Transmission: 700R4 and 700R4
Axle/Gears: 9 bolt 3.27, unknown
pm sent!
Car: 1990 Camaro IROCZ
Axle/Gears: 3.45
Re: PARTING OUT 88 IROC Z -WILL SHIP MOST PARTS
What color is the interior? I need med gray. Looking for left and right front kick panels and an inreior trunk lid from a car that had a power pull down hatch.
125 shipped for clutch/brake pedal assy
Interior is gray. Have kick panels and rear cover. You want the one on hat h or the one that covers pull down motor?
Car: 89 Iroc Convertible
Do you still have the fog lights,hood louvers and seat belts available?
Pm me your email for pics
Lots of parts. Factory wonder bar/steering brace, z28 iroc dash emblem, any thing is for sale!!
3 good-15" aluminum wheel irocz center caps
15" irocz wheels, 1 has ding on lip, all others good
175
175
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
Is rear spoiler center section in good shape? How much for spoiler shipped to 98844? Do you have photo? Thanks
It is in good shapeprobably around 70 shipped.what's email to send pics
Pm me shipping location for est with shipping
Rpo codes
Dash vent set, license plate mounts, switches. Horn button, lights, etc what do you need? Just ask!!
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
Do you still have the dual fans ? And would you sell just the fuse cover piece. Do you also have the trim piece that holds the lock/unlock button driver side. How much shipped to Miami 33010
I'd sell you the parts for 75. That's the fan setup, the whole underdash fuse panel, and the power lock switch bezel. The shipping is 65. 140 total. The fans and shrouds are heavy, and they need a big box. Just let me know
Shopping would be expensive. I was planning the full ls1 brake conversion as I'm doing the ctsv swap on my 4th gen camaro. And selling the spindles with ls1 brake setup complete with calipets and rotors for 300
Otherwise just spindles would be 70 for pair plus shipping
Hatch pull down motor 70 shipped anywhere
Headlight bezels and mounting buckets-40 shipped
Great original shift boot too
1.5" wheel spacers hubcentri
c 60 shipped set of four
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Do you have the plastic rectangles for the hatch pull down assembly?
http://www.thirdgenranch.com/86-91-c...otor-guide-kit
Selling whole power hatch pull down latch assy. Only
Car: 1988 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 2.77 Posi
Interested in the owners manual and associated literature pictured. Also interested in the drivers side lower/under dash panel, if available. Shipping to 73080.
Can ship it all for 45 total. Just let me know. Can send out tommorow usps.
Still lots of parts here. Anything and everything from car is for sale!!!!
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
How about all the emission lines and all other parts for the emissions complete?
Are you taking about the AIR system or EVAP? I can do either
Lots of parts. Air system parts,A/c parts, exhaust parts, engine parts, cooling system parts, interior parts. WHAT DO YOU NEED? PAYPAL ONLY
Wiring harnesses available as well
Would prefer to sell with tpi setup. The original was defective so I had to get a reman'd or previously enjoyed one
Still lots of parts, most smaller items can ship for 7-15 bucks. Usps large box is $15 and is 12x12x6. So if what you need can fit in that size box with proper packing or bubblewrap, then it's 15 or less anywhere in usa. Let me know what you need. Bigger items seem to be 40+, such as bellhousing, dual fan setup,etc.
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
Pass under dash shipped to 11756
Also if dual fans avaible that 2
Thanks chris
Thanks chris
Pm sent trafficlightguy
Lots o parts here!!!
Bellhousing, clutch pedals, 5spd console plate with original shifter boot in great shape!!
Will sell ecm and engine harness for 150. For 305 tpi and 5spd. Also have tailight, main interior harness,etc. What parts do you want?
