[VT] LS1 fbody brake/spindle set up for 82-92 camaro and firebird
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Pair of modified spindles, adapter brackets, calipers,rotors etc. This is the 98-02 f body brake setup for use on 82-92 f bodys. You need 16" wheels minimum to work with these and may have to install longer lug studs. Aside from that, this setup is bolt in and ready to go. Pics included.
400 firm for pair
Local pickup/may travel from location if willing to meet in nh or ny.
802.310.2878
400 firm for pair
802.310.2878
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Re: LS1 fbody brake/spindle set up for 82-92 camaro and firebird
what proportioning valve did you use with these?
Stock one works fine from what I've read, even the non 1le
Wheel bearings are repacked with new wheel seals. Bolt on and go, uses the factory 3rd gen brakes hoses
update! 300 takes them away. dual piston ls1 calipers and 12" brake rotors,fits all 82 through 92 f bodies!
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
Willing to ship?
these are sold!
