[NY] AEM Electronics Water/Methanol Injection Kits 30-3300
Old Dec 20, 2016 | 06:46 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
AEM Electronics Water/Methanol Injection Kits 30-3300---380$
Comes with the windshield washer fluid bottle with sensor built on.
I Only used this kit on the dyno.
These AEM Electronics water/methanol injection kits allow you to increase boost pressure and advance timing without having to run higher-octane fuel. Also included is AEM Electronics Boost Safe output--this allows you to retard timing or reduce boost if the systems run out of fluid or detect an error. Once installed, the AEM water/methanol injection kits use a boost-dependent, variable-flow progressive controller to determine the amount of water/methanol mixture to feed into the inlet stream from the reservoir. Adjustments can be made with the three included jets, resulting in significant horsepower gains.
Old Dec 21, 2016 | 11:45 PM
Engine: 5.7 350 TPI
Re: AEM Electronics Water/Methanol Injection Kits 30-3300
Make me
Old Dec 21, 2016 | 11:46 PM
Engine: 5.7 350 TPI
Offers
Old Dec 23, 2016 | 08:57 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
How old is the kit?
Old Dec 23, 2016 | 08:58 AM
Car: 86' IROC
Axle/Gears: 3.45
Firm on the price?
Old Dec 23, 2016 | 09:58 AM
Engine: 5.7 350 TPI
Originally Posted by 86CamaroDan
Firm on the price?
The kit is about 2-3 months old. Text me for more details 3472174881
