1989 TPI intake system and other parts!
Old Feb 25, 2017 | 03:33 PM
lsturbo89's Avatar
Car: 1989 formula 350 turbo Firebird
Engine: 5.7L L98
Transmission: Stock
Very dirty but came off running 89 l98. Have other parts as well. PM for offers also have brand new MSD distributor w/ an older performance coil (Unsure age) fuel pump is Brand New! Injectors included with fuel rail but will need new donut rings most likely. The regulator is new but the bolts were stripped when it was disassembled, Sorry about that. You will need new gaskets for the intake pipes (Not sure about how the dents happened but no leaks). I had to use the throttle bracket for a retrofit on my car (Sorry still not good with terms) to do an engine swap. Anything in the pictures just send a PM with offer. The octagon thing is a vacuum fuel assist to force more gas, was used for a turbo setup. The two braided lines are oil feed and returns for said turbo setup but could (Probably) also be used for an oil cooler. Thanks for checking out my post!!
Attached Thumbnails 1989 TPI intake system and other parts!-20170225_153056.jpg   1989 TPI intake system and other parts!-20170225_153210.jpg   1989 TPI intake system and other parts!-20170225_153217.jpg   1989 TPI intake system and other parts!-20170225_153335.jpg   1989 TPI intake system and other parts!-20170225_153344.jpg
1989 TPI intake system and other parts!-20170225_153458.jpg   1989 TPI intake system and other parts!-20170225_153408.jpg   1989 TPI intake system and other parts!-20170225_153518.jpg   1989 TPI intake system and other parts!-20170225_153534.jpg   1989 TPI intake system and other parts!-20170225_153703.jpg
Old Feb 25, 2017 | 03:38 PM
lsturbo89's Avatar
Engine: 5.7L L98
Transmission: Stock
Re: 1989 TPI intake system and other parts!
<br>
I will be happy to ship everything but the hood, Which needs serious body work anyway, if you just let me know before the sale that you would like it shipped. Thank you!
Old Mar 4, 2017 | 02:29 PM
91rs1022's Avatar
Car: 89 Camaro RS
Transmission: 5 Speed
How much for the lower intake manifold shipped to 48723?
Old Mar 4, 2017 | 03:09 PM
lsturbo89's Avatar
Engine: 5.7L L98
Transmission: Stock
Pm sent.
