[AL] lb9 engine-injectors
Old Apr 12, 2017 | 04:49 PM
MORREALE5's Avatar
Car: 1987 IROC Z
Engine: L31 VORTEC
Hello,i have a nearly new set of injectors for lb9 (305) tpi injectors.there bosh 4 injectors(19lbs) in great working condition,less than a year old but maybe 5,000 miles on them.im asking $100 for all 8 injectors....im also selling the original 1987 iroc z lb9 305 tpi motor,the motor still has the tpi base plate on it.i recently installed a crane cams camshaft designed for the tpi engine.i have the original 5 speed cam also.the motor could use a rebuild do to age but it was a running and driving motor when removed from car.the camshaft has very low miles on it also.im asking $300 for the motor...$400 for injectors,motor,camshaft.i do have paper work for cam specs.the motor is in a crate in a warehouse so not in the weather,very clean...thanks...2052494532
Old May 9, 2017 | 05:37 AM
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
Re: lb9 engine-injectors
give you 75 shipped for the injectors
Old May 9, 2017 | 11:53 AM
MORREALE5's Avatar
Car: 1987 IROC Z
Engine: L31 VORTEC
Ok, pm me and ill get your information.
