[CT] TH350 swap
Want a title? Post!
Car: 1982 Camaro Z28 1987 Firebird
Engine: 305 Crossfire/350 TPI
Transmission: Automatic/Standard
Axle/Gears: 3.23/2.73
TH350 swap
This is the vast majority of what’s needed to run at TH350in our cars. There is a TH350 short shaft transmission. The transmission was ingood working order when removed earlier this week. There is a shift kitinstalled. I don’t know the specifics of it. There is a B&M Whole shot 2000stall torque converter. The torque converter has about 6000 miles on it. Thereis also the inspection plate/dust cover, speedometer cable, braided coolinglines w/ fittings, shifter cable, 3 speed shifter, Camaro console shifterplate, yoke, driveshaft, filler tube/dipstick and UMI cross member with torquearm. The UMI cross member has a driveshaft loop. The torque arm is adjustableand mounts onto the cross member not the tail shaft of the transmission. I’lltake photos in the next day or two and post them. The setup is in Enfield CT.Asking $1,200, but is negotiable.
Want a title? Post!
Re: TH350 swap
Bump for the photos. The filler tube and dipstick are not in the photos, but are included.
Want a title? Post!
Re: TH350 swap
Here are two additional photos. The transmission worked well when removed and the fluid came out bright red. A new kick down cable and helicoils for the transmission pan will be needed.
