[IL] FREE brackets pulleys A/C Alt exhaust stuff
Car: 1986 IROC-Z
Engine: 5.7 TPI, 113 heads, Comp Cam
Transmission: 700R4, 2500 stall
Axle/Gears: 3.42 Posi
Need to clean out my garage. I have a bunch of accessory brackets from '85-87 TPI Camaro, the A/c compressor from my '86, very little use on it. Alternator is gone. Serpentine brackets came from a car that had a procharger at one time. Still worked when the charger was removed. Misc 3" exhaust stuff. Make offers, I can take more pictures of anything too. Thanks!
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: brackets pulleys A/C Alt exhaust stuff
I need all the parts to do a serpentine belt swap from a v belt except for AC and the smog pump. do you have all the bolts as well?
Car: 1986 IROC-Z
I have some of the correct torx bolts but not all. The brackets were bolted up with whatever they could find. I will include any bolts I have. the alternator was on the same car too. It had a/c, but no air pump. Would need bypass pulleys for those.
Engine: 383 stroker
How much would you want for the alternator and all the serpentine brackets and pulleys?
Car: 1986 IROC-Z
How's $25 plus shipping? Send me a zip code I'll check cost.
Car: 87 K5 Blazer
Engine: 355 TPI SD
Axle/Gears: Corp 10 Bolt 3.73
Car: 1986 IROC-Z
Everything is still available.
The car these came from had a ProCharger on it but it was removed years ago. The brackets were modified but they were used for years after the charger was pulled. The big aluminum piece was on there but wasn't needed.
Car: 1986 IROC-Z
Re: FREE brackets pulleys A/C Alt exhaust stuff
Bump. Have everything but the alternator. Free if anyone needs somthing.
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
I'm looking for the V-belt alternator and A/C compressor brackets for a TPI swap I'm doing on my son's El Camino.....do you still have those?
Car: 92 Camaro RS Heritage Edition PoloG
Engine: L31 Vortec
Transmission: 4160e
Axle/Gears: 4th Gen Torsion Rear/ 3.42s
ill take radiator shroud and ac bracket if it doesnt sale before me
Car: 1986 IROC-Z
Serp brackets are gone. Still have the radiator bracket. Which a/c brackets?
