***$2,250***STRANGE ENGINEERING 12 BOLT W/Moly D/S & Torque Arm
Old Oct 21, 2017 | 09:20 AM
ambainb's Avatar
Car: 86 iroc
Engine: Iron 408 LS3 combo
Transmission: Ram10 T56
Axle/Gears: 3.73 10 bolt :)
The following was pulled from our 1998 Camaro drag car that we sold last year... We held onto the rear end... YES it was in a 4th gen but it is built for a 3rd gen and is the factory 3rd gen width HOWEVER it does have provisions for a reluctor wheel sensor for the 3 & 4way set ups in the 93-02 cars if you want to retain your ABS and Traction Control in a 4th gen it is possible... We went 7.1x's @10xmph in the car for 2 seasons and then sold it to fund another project ... Everything you get here will ALL BOLT IN.. with the addition of a Crossmember. The driveshaft was made to work with this rear end and a factory transmission(our car was a T56 car) so any 700r4/4L60, T5 or T56 car should accept this drive shaft.
We payed just over $600 for the driveshaft alone... so this is a steal... over $4,000 in goodies so I will not be negotiating altho I will entertain offers of trades WITH cash..
I am asking $2,500 for the package and dont want to split it up..
HD Strange Engineering 12Bolt 82-02 GM F-Body
The Following Upgrades and Options were all at an additional cost when this was purchased... so it is not your "run of the mill" or "off the shelf" 12 Bolt... it has some time and money invested into it.
-OE ​​​​​​Third Gen(82-92) Axle Width
-Upgraded Housing with Welded Axle Tubes
-Ford "Big End" Tubes and Bearings
-Strange HD Chromoly Pinion Yoke (1350)
-ARP 2x5/8" Wheel Studs
-HD 33 Spline Strange Axle Shafts
-Richmond Ring & Pinion (4.56) "Race" Gear Set
-HD Strange Steel Spool "Race"
-11" GM Drum Brake Kit (all new)
***Can Swap too 4th gen disc brakes (PBR or SS) or just include the parts***
-LCA Relocation Brackets (1",2" & 3" drops)
-Drilled for 3-Way Traction Control (not being used but you can set up for it)
***Also Included***
-Strange Engineering 3" Chromoly Drive Shaft
*Upgraded HD Chromoly 1350 Transmission Yoke
*Set of Quality 1350 U-Joints
-Tubular Afternarket Adj. Torque Arm
*Heavy Duty Torque Arm Bracket for the 12Bolt (This is a very solid piece and has taken hard launches through a manual car that pulled the front wheels... I know there has been issues in the past with the MOSER units and some D60's but not this one) actually the previous torque arm we had in the car was a tubular adjustable Edelbrock Torque Arm and it twisted the center of the arm bad.. so this ones tried and true lol...
*Red Power Coat...
*For use with stock style bushing ... We had one of the common BMR Crossmember's that mounted the torque arm off the trans and too a slotted plate on the X-Member to allow for actual Anti-Squat Adjustments in addition to pinion angle..
So in total
-Strange 12 Bolt w/Brakes
-Strange Chromoly Drive Shaft w/U-joints and Yoke
-Tubular Adj. Torque Arm w/12Bolt Bracket Assembly
$2,500 takes it
I am located in Buffalo NY (14228) and I do have the ability to ship... it will be at the buyers cost but will be crated up well..(figure on $300 for shipping)
I definently would prefer pic up, or I can even deliver depending on how far the drive is.
Please text me @ (716)428-1674 make sure to mention your name and what you are inquiring about as I have many different items for sale.
Thanks for your time,
Adam B.
Old Oct 22, 2017 | 12:29 AM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: STRANGE ENGINEERING 12 BOLT W/EXTRAS
Damn. So close to what I am looking for., and not too far away.
Old Oct 24, 2017 | 12:11 AM
ambainb's Avatar
Car: 86 iroc
Well come and pic it up. $2,200 and it's yours
Old Oct 25, 2017 | 10:57 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
The exchange rate would kill me on that.
