Vortec 350 heads and long tail th350
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Have a set of vortec heads. Valve job around 1000 miles ago. Also been worked for bigger cam. 062 casting. Have a jegs intake also to go with. $400
Also have a long tailshaft th350 that needs rebuilt. Perfect for a swap reuse stock driveshaft. $100
Willing to.ship heads and intake trans is a little harder. Located in Iowa.
Engine: 383
Re: Vortec 350 heads and long tail th350
Not 100% because I didnt have them machined but motor they were on had an lt4 hot cam with 1.6 rockers. .525 lift. I will let you know on shipping.
Did look up your zip you're only 2.5 hours away. Might be cheaper then shipping.
