383 and Auto transmission ( engine sold)
Car: 1986 Iroc Camaro
Engine: 5.3 ltr
Axle/Gears: moser 9in, 4.56gear
I have a 383 chevy engine up for sale. Currently in my Camaro. Going to wait to pull it so if you are interested you can hear it run and I can take you for a ride. Specs are as fallows- scat 4340 steel crank (internal balance) 6inch eagle H beam rod L19 ARP bolts SRP FLat top forged pistons Comp cams top end Chromolly push rods Solid flat tappet lifters Valve springs, retainer, keepers Cloyes timing chain (adjustable) Cloyes timing cover Harland sharpe Roller rockers 1.5 ratio Edlebrock e tec 200 heads Ferera heavy duty valves Ported intake & exhaust runners Debured combustion chamber 4 Angle race cut valve job Milled to a 60cc combustion chamber 4 bolt main block 0 decked line honed deburred all ARP fastenars studed mains and bolts for heads. Studed rockers Edelbrock intake Can include the carburetor for and additional 500. Its a Holley hp 950.
700r4 transmission
Precision converter (4 disc lock up, 3500 stall, Paid $800)
Coen super drum
TCI reverse manual valve body
Looking to get $1000 for it.
If interested i have a video of the engine running that i can send. Thanks for checking out my add
700r4 transmission
Coen super drum
the209bnr
Jun 29, 2012 01:48 AM
eeeeeefirebird
Mar 4, 2011 11:50 PM
eeeeeefirebird
Dec 12, 2010 10:36 AM
BlueZee28
Jul 3, 2010 12:16 AM
