San Antonio, TX - 91-92 Speed Density TPI and .030 over 4-bolt 350
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
I have a .030 bored 4-bolt main roller cam 350 (code on block 880) in good shape with crank, pistons, oil pan, timing cover, and rear seal. Have L98 or LT1 camshaft available. Asking $300 for short block. Also 1991-1992 Z28 speed density TPI system with upper plenum, lower intake, runners, fuel rails, injectors, EGR, wiring harness, and 0730 ECM. Asking $300 for TPI system. Have TPI 350 cylinder heads (casting 081) in good shape with springs and rockers, asking $200 for pair. Was pulled as a complete unit, torn down for cleaning and machine work but better project came along. Will sell everything above together for $500. Not interested in low ballers.
Also have complete 1982-1984 Z28 ground effects and front/rear bumpers. Driver side fiberglass rocker needs repair. Asking $100 for complete set.
Have various interior 1982-1992 panels in red and grey. Asking $5/piece.
Have 1991-1992 Z28 high rise spoiler, asking $100.
Have 1982-1992 glass T-tops, mismatched pair (with/without black border). $25/each.
https://sanantonio.craigslist.org/pt...936739911.html
Last edited by 1983Chimaera; Jul 18, 2019 at 11:00 AM. Reason: Updated info/prices/more parts
Re: San Antonio, TX - 91-92 Speed Density TPI and .030 over 4-bolt 350
Added more parts. Please bump.
87frankenbird90
South Central Region
Mar 27, 2007 08:51 PM
'87FAKE-IROC-Z
Feb 3, 2002 08:54 PM
