[CO] TPI Engine Parts, misc [Price Adjustment]
Old Mar 7, 2020 | 06:50 PM
ChevyTycoon's Avatar
Parts leftover from a recent part-out. All parts plus shipping and paypal (if not family)
Air Snorkel, includes rubber - great shape but needs a good cleaning; $35
89-92 camaro fuel rail (no cold start), excellent condition; $55 (keep the 7 injectors or i can toss them to save a bit on shipping)
Upper Plenum, with distributor cover, MAP sensor, IAC, throttle bracket, Throttle Body, excellent condition; $100
86-88 Camaro TPI Baseplate. great condition, no stripped holes. Removed the oil baffle plate from the bottom to clean it up, but the baffle comes with it. Coolant neck included. part # 14081005. $125
89-92 TPI Runners. very small dents on Right side, but Left is perfect! No CSI. $40 for the pair.
Small-cap distributor, perfect working order but needs a good cleaning (and cap + rotor); $50
Camaro Hard Fuel Lines that connect from the rubber to the rail base plate, pair, perfect condition (needs cleaning); $50 - SOLD
Corvette Hard Fuel Lines, with the pair of rubber lines as well; $75
Center bolt valve covers. in nice condition (did solvent-tank cleaning on these) and with bolts; $40
A few options in terms of Wiring Harness:
1. Factory engine bay harness in great condition. Injector wiring and plugs are great, MAF setup with small distributor setup. Entire harness from firewall forward including some of the relays and brackets. I haven't looked at each and every connector but many of them are perfect, not broken. There are 4 cut wires but plenty of length to patch in a repair if needed. Also included with this is a full rear tail light harness in good condition. $35
2. An MAF TPI conversion harness from Painless (originally ordered for a '42 coupe. This is an INCOMPLETE harness as the Injector wires were cut and used on another build. Also, there is no transmission wiring for lockup converter. The harness includes a small fuse-block as a stand-alone unit. The rest of the harness was never used, and is fully labeled. For the most part, this is a "parts only" harness from which some connectors can be salvaged but its not capable of "plug and play". I'm willing to add this to the factory harness for additional connectors if desired; $25
3. A MAF TPI conversion harness from Painless. This is a full conversion harness, never used, fully labeled. Comes with ALDL connector, lockup converter, VSS, no Cold Start. I was going to use this in a 70 Blazer so i'm unsure if this would retro-fit into a factory setup. $300 - SOLD
I am willing to mix and match pieces if there is interest in doing that.
Shipping will be *from* Englewood, CO 80113 and hit my picture limit so more pic's available upon request.
Old Mar 8, 2020 | 09:51 AM
Re: TPI Engine Parts, misc
Old Mar 8, 2020 | 11:08 AM
Old Mar 30, 2020 | 09:31 AM
Re: TPI Engine Parts, misc [Price Adjustment]
TTT
Old Apr 3, 2020 | 07:57 PM
mizz0313's Avatar
Car: 92 Camaro RS Heritage Edition PoloG
Engine: L31 Vortec
Transmission: 4160e
Axle/Gears: 4th Gen Torsion Rear/ 3.42s
air snorkel shipped to 15122. Thanks
BizJetTech
Jul 27, 2019 01:17 PM
LC2 TECH
Jul 25, 2019 09:32 PM
TCoupe
Mar 16, 2019 03:29 PM
96BlownSSragtop
LSX and LTX Parts
May 24, 2017 03:09 PM
lynchmob
Jun 6, 2012 02:49 PM
