I know it’s not the most desirable motor but just seeing if anyone needs a 305 tbi from a 1990 camaro. It is complete from oil pan to tbi unit. Stock exhaust manifolds as well come with it. From what I can tell it’s all stock. There is no engine harness or ecm with it. I just did a fresh oil change, the previous oil was clean. I have not personally heard the motor run but as I said everything that I can tell looks good, I pulled the valve cover and there was clean oil and all the rockers and pushrods looked good as well. I was able to turn the motor by hand after removing the plugs. The plugs looked normal, no evidence of coolant in the cylinders. I am only looking to selll it because I have access to a 305 tpi that I can get for the same price it would cost me to buy a harness and ecm, unless I would just run the tbi. The accessory drive setup is not included with the motor, I will be swapping that to the other motor. I’ll take any reasonable offer.
let me know, pm me.
I will not ship it, I’m am located in NY.
