located north shore, Massachusetts
I have a 1985 formula firebird project that I've lost interest in. Car doesn't run but it is a rolling chassis and all the parts are there. Really a collection of parts more then a car. In no rush to part out the car. willing to take $6,000.00 for everything.
Lots of stuff. Ask and ill tell you if i have it. Full UMI suspsion, Koni dampers, Eibach springs.
83-92 UMI GM F-Body Boxed Style Weld-In Subframe Connectors - $250
982 - 2002 GM F-Body Lower Control Arm Relocation Brackets - Bolt-In - $100
1982-2002 F-Body On-car Adjustable Control Arms- Poly/Roto-Joint (2039) - $300
1982-2002 F-Body on Car Adjustable Panhard- w/ Roto-Joint (2037) - $150
1982 - 2002 GM F-Body Panhard Bar Relocation Kit (2024) - $200
1982-1992 GM F-Body Heavy Duty Billet Aluminum Tie Rod Adjusting Sleeves (2103HD) - $50
fbody tubular suspension Torque Arm [broken grease zerk] - 150
1982-1992 GM F-Body Tubular K-member, Factory Springs, Road Race (2407) - $700
82-92 GM F-Body Spherical Caster/Camber Plates (2040) - $250
1982 - 1992 GM F-Body Front Lower A-Arms, Polyurethane Bushings (2031) - $600
KON-8741-1 Koni front shock, single adjus; KON-30-126 Koni rear shock, off-car adjus - $700
SUBFRAME CONNECT/BOLT - Inner - $200
Eibach 3801.140 Pro-Kit Performance Spring Kit - $250
body of car - $500
gen 4 body wiring harness - $100
1975 Corvette Engine - $500
Gen 4 plastics gas tank - $100
T5 WC transmission with SBC bellhousing - $500
gen 4 rear end - needs to be rebuilt - ls1 w/ brakes - $500
CTS-V big brake Upgrade - 1200
body of car - $500
92WS6 T/A
close
Pics?
Is the rear end limited slip? When you say needs rebuilt, do you know what issues it has?
What's the ID number on the T5 trans? Willing to ship?
Are your UMI parts red or black. Is your torque arm adjustable or fixed?(2206-R) Can I get a picture of the broken grease zerk? Will you ship? Thanks.
