[MI] GM SBC custom intake
Engine: SD 5.7 TPI
Axle/Gears: 10 bolt 3.42 LSD
Received this on a package deal. Have fuel rails to go with. Lt5 throttle body. $450 plus shipping
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: GM Prototype intake
Pics of runners please
Engine: 4++,350 & 305 CIs
Thought those were used on some boat engines?
Engine: SD 5.7 TPI
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
I have a 92 camaro with 350 and 5 speed and t-tops from the factory. No such thing from GM on the Camaro I just described.
Do you see what I mean?
Documentation will help your sale.
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: GM SBC custom intake
did you buy the zz4 heads with it? id be interested in both for what they were listed for.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Does the top come off to expose the plenum or is that just a cover for show?
Pics of the underside please - particularly that alum plate that is bolted on
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Any idea what is going on w/that "skirt" all the way around the base of the....plenum, is it?
How about, any idea what fuel rails it "wants"?
the thing is definitely a unique looking unit.
Engine: SD 5.7 TPI
Plenum over the runners. Factory fuel rails bolt on. Have a set to go with.
Engine: LT1, L400
I'm still trying to figure out the "turtle shell", or "skirt" long the bottom of the plenum. I'm interested in buying this thing, but want to understand it better. Do the runner protrude into the plenum? Like the BMW M5, "Box of snakes" intake? So the "skirt" isn't a wall, it's actually part of the plenum? Odd looking but I like that it's different.
Engine: SD 5.7 TPI
They are flush to the plenum. Open plenum with Removeable anti reversion plates.
Engine: LT1, L400
Thanks.
IDK what to think of it! On the inside, it looks fabricated. IDK. It looks like the rear runners are shorter than the fronts?
Engine: SD 5.7 TPI
It is fabricated, all runners equal length. Reversion plates Removeable for open plenum.
Wow, I wish I knew what the history on that was/what it was designed for. I've never seen anything like it and not sure what is going on with what you're calling anti-reversion plates. I've been very into some more obscure especially SBC stuff and I've never seen anything like this.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.ebay.com/itm/165132759847
If anyone needs I have these rails , would go well with the intake
Tuned Performance
Jun 3, 2021 10:57 AM
kawaslut
Dec 27, 2019 11:04 AM
92RSsleeper
Aug 9, 2009 02:02 AM
