[CA] Spohn Driveshaft Loop
Old Jan 2, 2023 | 04:34 PM
Speed Racer's Avatar
Car: '87 Camaro Sport Coupe
Engine: 383
Axle/Gears: Ford 9, Detroit Locker, 35 sp, 4.11
Prevents certain disaster from a driveshaft or front joint failure. Red powder coat. Normal scuffs and scratches. MSRP is $100. Asking $50. Located in zip 95401. Package is 13.5"x5"x18" 7.5 lbs. You can calculate exact shipping costs to your location, but it should be around $10.
Drill two 7/16" holes through your stock transmission crossmember. Our loop mounts to the underside of the stock transmission crossmember. You simply place two 7/16" bolts (NOT INCLUDED) and washers through the driveshaft loop mount, through the transmission crossmember, and into the polyurethane transmission mount (required and NOT INCLUDED).
Want a matching torque arm too? See my other post here.
Bavooz Flo
Nov 23, 2022 10:06 AM
thewolf
Jul 14, 2008 11:31 PM
