[Sold] T56 Swap
Old Nov 19, 2025 | 11:33 AM
Doobie52's Avatar
Car: 1992 Trans Am
Engine: 6.0 LQ4
Transmission: T56 Magnum F
T56 Swap
Finally moving forward with an LS swap on my 1992 Trans Am, so instead of rebuilding my LT1-style T56, I’m taking the recommendation from the team at Tick Performance and purchasing a new transmission. Because of that, I’m putting my complete, well-maintained T56 swap setup up for sale.
I originally completed the T56 swap about 10 years ago using parts from a low-mileage 1995 Z28 Camaro that had been totaled. I bought the entire car and pulled everything needed for the conversion myself. Since then, I’ve put an estimated 6,000 miles on the transmission. The car has only has a stock 305 in it, so the T56 has lived a very easy life.
Included in the sale:
  • LT1-spec T56 transmission
  • LT1 bellhousing
  • MGW shifter
  • BMR transmission crossmember
  • GM clutch hydraulics
  • Flywheel and complete clutch assembly
  • Starter
If you're installing this behind a TPI or LT1 engine, your stock driveshaft will work without modification.
Feel free to message me with any questions. The only additional part you’ll need is a clutch pedal assembly—either a third-gen unit or an early (’93–’97) fourth-gen F-body pedal set will work.
Dropping the price because I didn't know the state the clutch and flywheel were in prior to pulling them out.
Price: SOLD
Shipping: Willing to ship at buyer’s expense.
Old Dec 2, 2025 | 11:00 PM
Doobie52's Avatar
Car: 1992 Trans Am
Engine: 6.0 LQ4
Re: T56 Swap
Old Dec 3, 2025 | 02:40 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: T56 Swap
This is awesome, someone should jump on this!
TheMagikMan
Apr 16, 2023 05:35 PM
mcweens
Jan 11, 2015 12:25 PM
blaznbrd
Southern California Area
Oct 29, 2003 12:42 AM
