Mechanical Clutch Linkage
Car: 1985 Trans Am
Engine: Chevrolet 355
Transmission: Borg Warner W.C. manual cog
Axle/Gears: B W 9-bolt 3.45 Limited Slip
I'm doing the auto to T-5 swap and am looking for the complete mechanical clutch linkage ( 82-3? ) from the pedal to the throwout fork.
Re: Mechanical Clutch Linkage
did you have any luck with your set up? my father in-law just bought an 82 camaro with a t-5 in it with mechanical linkage and it is a real hack job and i have to fix it ,its wearing out the pedals. what were you able to do? i would like to find the stock set up for it but cant find any info either.
Car: 1985 Trans Am
I could not find any of the mechanical setup in good condition so i opted to go with the hydraulic setup which was quite easy ,except for the bleeding of the slave cylinder,as i went with an aftermarket instead of the pre bled GM, but as long as you "reverse bleed" it , no problem. Maybe you should go with the hydraulic. It works good and less moving parts. If you have any problems feel free to e-mail me if you wish.
thanks abunch for your reply i will talk it over with my father in-law, but i know his answer already . my other question though is did 82 come with mech. or hydr.? i do know 83 are hydr. thx. again
Car: 1985 Monte Carlo SS
Engine: 5.7L
Transmission: WC T-5
Axle/Gears: 3.73:1
Night rider327
Sep 2, 2015 04:17 AM
