WTB: Intank Fuel Pump Assembly...
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
I'm looking for the entire intank fuel pump assembly, including: float, sending unit, lid, and 6" of the steel fuel lines... as, I'm doing this via the Access Panel route.
Basically, everything that goes inside the fuel tank... and around 6" of the hard lines connected/cut.
Anybody have anything laying around that works ?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a Complete unit from the in-tank pump to where it connects to the rubber lines at the body. I'll bet it still has the lock ring and the rubber seal on it too. It worked when it was pulled......
Make a realistic offer for it and include your ZIP CODE so I can get quotes if your interested. I will include a shipping qoute in my next reply.
Transmission: Pro-built 700R4
I have a brand new AC Delco fuel pump if you are interested. Asking $40/obo
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Axle/Gears: 3.42:1
I just spent $30 shipped on WHAT WAS SUPPOSED to be an Electric In-Tank Fuel Pump Assembly from a fellow board member named Woody Pruitt of Albertville, AL...
...however when it arrived it was the in-tank float and 90 ohm assembly from a mechanical fuel pump car.
Hey WOODY... are you out there ?
Back on the hunt... does anyone have an ELECTRIC in-tank fuel pump assembly for sale OR an electric fuel pump for my '89 Camaro ?
All help appreciated, thanks.
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
I have a complete working unit out of a 1988 formalu.
Drive down to Galion Ohio and pickup 40.00
You also may see other parts you need I have a shop full.
Jeff
Jeff
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
