needed: pair of L98 heads (113 castings)
As the title implies. I need a set of 113 casting L98 heads, complete or otherwise. Problem is, i dont have alot of cash on hand, so if someone has a set theyre willing to part with cheap...
thanks in advance
smith
thanks in advance
smith
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
981 duel springs, .600 lift clearance, ARP screw in studs, 10deg locks, stainless exhaust valves, brand new valve job 14deg back cut on all... all comp cams parts... porting done 1205 gasket match, smoothed out all imperfections, bowl cleaned out...bumps removed from floor and ceiling...
cumbustion chambers untouched.
just not enough head for the cc306 cam and HSR intake.... going bigger
pm if interested ( 081)
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
