WTB: 350 or 383
Old Jun 14, 2007 | 07:04 PM
Soccerman133's Avatar
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
WTB: 350 or 383
I want a 350 or 383 than i can put in my 85 TA. it is ok if it needs rebuilt as long as the block is in good shape. preferably under $500.
location= near pittsburgh
Old Jun 15, 2007 | 07:27 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: WTB: 350 or 383
I got a fresh block I would send you for $250 plus shipping... I'm in Hattiesburg, MS 39401. All the machine work is done. I put 500 miles on it. You can still see the hone marks in it.
Old Jun 15, 2007 | 08:31 AM
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: WTB: 350 or 383
4 bolt? ci's? year? etc? any pics?
Old Jun 20, 2007 | 12:49 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: WTB: 350 or 383
It is a 2-bolt block, 350 bored 30 over makes it 355. 1994 roller block. don't have pics. I don't have a camera to take any. I will see if i can get some but can't promise. The 2-bolt block is good up to 600 hp with the stock caps. You can put splayed 4-bolt caps on it and it will be stronger than any 4-bolt block you find. I will throw the pistons and rods in for another $50 so $300. One piston will have to be replaced and two rods need to be replaced.
Machine work done:
bored and honed 0.030"
new freeze plugs
new oil galley plugs
new cam bearings
pistons pressed on rods
all caps matched by machinist(main and rods)
cleaned in a vat after machine work was done
checked for cracks before machining
This block is ready to be assembled.
Old Jun 21, 2007 | 10:10 PM
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: WTB: 350 or 383
How much of a pain will it be to swap it?
Old Jun 22, 2007 | 07:20 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: WTB: 350 or 383
what do you mean swap it. You have a 305 in now? if so then you can use almost everything on your 305 on here. Only thing your heads would have a smaller chamber so it would raise the compression a little. It would be an easy swap. If you have all the gaskets and such you can do it all in a day. I've been known to.
Old Aug 3, 2007 | 01:56 PM
blkcamaro19's Avatar
Re: WTB: 350 or 383
i got a 350 bare block knocked out .30 over . 4 bolt main new cam bearings new freeze plugs 0 miles been sitting on shop floor since machining.. i bought a lt1 car so this stuff is no good.. lookin for 300 plus shipping
Old Aug 4, 2007 | 01:32 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: WTB: 350 or 383
I have a L98 short block that has 88k on it, virutally no wear, but has a couple of burned pistons. 250 bucks, in NY zip 12566, pick up only though. It has cam/lifters/spider hold down as well, just the heads are taken off.
Old Aug 4, 2007 | 09:07 PM
latrobefbody's Avatar
Car: 83 Trans Am / 79 Camaro/dune buggy
Engine: 400 TPI/406 /1911
Transmission: WC T-5/ T-56 (looking)/bus trans
Axle/Gears: 3.42/3.73/4.56
Re: WTB: 350 or 383
# on back of block 10243880
I'm in Latrobe,PA.
I have a 350 4 bolt main engine with less than 100 miles on it.
Pulled out of 88 Formula....not original of course
Roller block.
.030 over flat top hyperuetectic pistons hanging off of powdered rods.
Has a Crane cam in it,not real big,lost specs.
62cc heads
It is not the Vortec engine as it has the provisions for the mechanical fuel pump.
Everything in the engine is BRAND NEW.
Not a bit of smoke.
Windage tray.
I know you said $500 or so,but heres something to think about.
$900 and i'll deliver it to you.
It's already out.
I guarantee it.
All the hard work and money has been put into this engine,all you do is drop it in.
Attached Thumbnails WTB: 350 or 383-img_0015.jpg   WTB: 350 or 383-img_0016.jpg
Old Nov 17, 2007 | 08:56 PM
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: WTB: 350 or 383
any of you still have those?
Old Nov 18, 2007 | 03:59 PM
Fast3rdGen's Avatar
Re: WTB: 350 or 383
i have a complete 383 ready for a distibutor and oil pan, ready to run. let me know if you are interested. i would be willing to sell the short block for 1k. it has an eagle cast crank, 6" eagle h-beams, dished kb pistons(all internally balanced), studded 2bolt 010 high nickle block. for another 500 i'll leave the alluminum timing cover, new double roller timin kit, new .540/252 dur @50 roller cam and speed pro retrofit roller lifters. cam lifters and timing set are all new never ran and the shortblock has less than 200 miles on it.
Old Nov 18, 2007 | 06:07 PM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: WTB: 350 or 383
Price lowered down to 125
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
