looking for tpi
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: looking for tpi
Do you have a preferance as to what year - style it's from ???
Pre-86 or 87 and later.
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Car: 92 Camaro RS
Engine: 305 TBI
Re: looking for tpi
I have a complete TBI to TPI swap. I bought it on this forum a while back for my 92 RS but I just don't have the time to make the swap.
This is the speed density setup with 730ECM from a 91 Z28. I have all the induction piping including K&N filters, fuel rail, injectors, adjustable fuel pressure regulator, TB airfoil and TPIS plate. I also bought the aluminum distributor cover so it could be polished to match the intake. I also have the wiring harness and I should still have the diagrams as well.
Everything has been media blasted, I just never got around to powdercoating or painting anything. I had started to polish out the upper plenum but never finsihed. The EGR block off plates and thermo housing were powder coated. I have all the bolts to assemble the TPI as well.
Here are some photos:
http://www.ironman24.carolinafbodyclub.com/temp/TPI/
Let me know if you are interested.
Sanjay
Aug 12, 2015 03:41 PM
