need wc t5
Old Oct 8, 2007 | 10:20 PM
withoutanycause's Avatar
Car: 87 iroc-z28
Transmission: th350
need wc t5
looking for a wc t5 nothing too expensive, can pick up within couple hundred miles of MN or will pay for shipping if the price is right.
Old Oct 9, 2007 | 11:57 AM
iggy89's Avatar
Car: 86 Camaro
Engine: 79 350 carbed
Transmission: TH-350
Axle/Gears: 3.73 posi
Re: need wc t5
I got one in WI. What all where you looking for? Just the tranny? or all the parts to make a conversion?
Old Oct 9, 2007 | 05:56 PM
Car: 87 iroc-z28
Transmission: th350
Re: need wc t5
i need the tranny, flywheel, pressure plate, clutch, and slave cylinder. converting from manual v6 to v8 and i already have the bellhousing. do you have an asking price?
Old Oct 10, 2007 | 02:28 PM
iggy89's Avatar
Car: 86 Camaro
Re: need wc t5
Well what I do have for sure is the tranny and the bell housing when I bought the transmission. I paid $400 for it and I would like to get at least what I paid for it. The guy that owned it before me said he only put 3000 miles on it since it was rebuilt at a shop. He even game me the receipt from the shop. Only reason I am not using this anymore is because I changed my mind and am going to go t56.
Can't you use the slave cylinder from the v6? I thought you could and was going to just use the parts off of a v6 firebird if I was going to install it into my camaro.
I do have a flywheel that should work for you. The guy that had my camaro was going to put a t5 in his and he ended up giving me the flywheel with the car. I can't use it since I have an older motor. When I get home I will check and see if there is a part number on it and will see if I can find any information on it.
Old Oct 10, 2007 | 02:41 PM
Car: 87 iroc-z28
Transmission: th350
Re: need wc t5
$400 sounds pretty fair. and yeah i could use the old slave cylinder but my buddy was trying to press the clutch in and he pressed way to hard and snapped the slave in half... should be pretty easy to find one since you dont have one. where are you located so i can figure out what the best day for me to drive out would be?
Old Oct 10, 2007 | 03:33 PM
iggy89's Avatar
Car: 86 Camaro
Re: need wc t5
I am over in Antigo, WI. Is in the central WI area. Looks like about a 4 hour trip. How did you want to make payment? I will PM you the address when you get it figured out.
Old Oct 10, 2007 | 04:48 PM
Car: 87 iroc-z28
Transmission: th350
Re: need wc t5
i figured cash would be easiest but if you prefer something different thats fine. would later next week work for picking it up?
Old Oct 12, 2007 | 09:30 AM
iggy89's Avatar
Car: 86 Camaro
Re: need wc t5
Just checking...did you get my PM?
