350 NEED PARTS for 400hp
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I have a 350 chevy 4 bolt main bored .60 over
I'm going for 390-430 horsepower
I need The following
Heads (lt1, ls1, l31, fastburns etc)
Camshaft (4.80-5.10 lift)
Crankshaft (possibly)
Pistons
650cfm Carb
Intake Manfold
Valve Covers
Don't have much to trade with unless you want a 700r4 or a complete 305 80000 miles
Pistons
650cfm Carb
Intake Manfold
Valve Covers
Re: 350 NEED PARTS for 400hp
I have a 650 double pumper in like new condition $250. I also have a set of fresh Vortec heads that have been machined and have Comp Cams springs, have been port matched. I also a GM performance intake comparable to a performer rpm. I have Comp Cams roller cam and lifters, specs are 495/503 lift with 218/224 duration. I'd take 800 for the heads, intake and cam or $1000 for everything. Heads also have stock valve covers.
I can ship all of this, I'm in Oklahoma.
This setup would be simliar to a HOT LT4 setup.
Thanks...
Thanks...
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
I have a roller cam that is out of a ZZ4, i beleave the lift specs are what your looking for. I have a 650 holley, that needs to be rebuilt. 125 shipped for both sound good??
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
It came out of a van from the early 1990's. I thought they did away with 4 bolt mains in the 80's for chevys?? But the dipstick is on the passenger side so it has to be a newer style block.
Transmission: t-5
i have a set of brodix 11x heads with a matching cam. Also includes retro fit roller lifters, 1.6 roller rockers and harden pushrods. I have all the paper work and less than 1k from a freshen up. call if you interested and want more info. 262 745 2432 my name is jerry. asking 2000
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i have a wieand 7546 single plane intake for sale. $80 shipped.
