LT1 T-56 Swap Needed.....
Want a title? Post!
Car: 91' Camaro RS
Engine: 327
Transmission: T5 Manual (conversion)
Axle/Gears: Z-28 rear with Richmond 3:73
Im swapping my 91 rs from 305 to lt1 t56.
so i need the following:
-Water Pump Housing
-LT1 Intake--(Pending)
-Stock Fuel Rails--(pending)
-LT1 throttle cable--(pending)
-T-56 slave cylinder
-LT1 Driveshaft--(pending)
-t56 trans
-rear end
-Pref. OBD2 computer
-Headers(longtubes)
-Short Throw Shifter
Thats basically the only parts i need to get going. T56 should be stock and hopefully never rebuilt. Anything else you might have that i might need just pm me! Im located in central Ky and will drive to get things cheap! Also im buying some parts now and then some in a few months! I have a orig. 305 bored to a 309 w/ a t5 trans that i will trade for parts or sell! Thanks, jf
so i need the following:-Water Pump Housing
-t56 trans
-rear end
-Headers(longtubes)
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: LT1 T-56 Swap Needed.....
Do you need a crossmember? I have a Spohn crossmember
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Want a title? Post!
Car: 91' Camaro RS
Engine: 327
i just ordered a intake and water pump. Thanks tho!
not going to get costly.....ive got onlt 400 in a complete motor from intake to pan. 60k miles on engine. now im pending sale w/ t56 and computer. Ill keep this updated.
thanks
thanks
Last edited by need_2_speed10; Mar 14, 2008 at 01:17 PM. Reason: Automerged Doublepost
I have an unused aftermarket Tremec T-56 that I bought brand new and never installed. It has the shifter relocated forward so the shifter is in the correct location. It has the adapter plate to attach to a t-5 bellhousing. $1800
I also have have the bellhousing, clutch, pressure plate, master/slave cylinders and pedals if you want them, $100. Located in Ste. Genevieve MO.
Hello, Michael
Aug 20, 2015 03:19 PM
