I need 4l60e parts!
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
I need 4l60e parts!
I'm hoping someone has a 4L60e torn apart and sitting in a box in the corner of their garage somewhere.... Or maybe you know someone that does?
I need a couple parts to add a VSS to a Jerico Trans:
40 tooth tone ring - It's pressed onto the outpshaft of the trans. Probably pretty tough to get off, so if you want to send me the whole shaft that's cool.
Vehicle Speed Sensor (VSS) - It's located in the passenger side of the tail housing.
Harness connector for VSS - self explanatory
These parts can be found in 1993 and newer 2wd trucks and 1994 and newer rear drive cars.
This is a long shot but I'm also looking for a DRAC (digital ratio adapter controller) from a 89-94 S10, Astro Vans, and 90-95 full-size trucks. The VSS is wired into this and it conditions and applies a ratio to the signal that goes to the speedo and ECM.
Let me know if you can help! Thanks, Stan
Re: I need 4l60e parts!
The vss they still make, carquest has them.
The drac also called a speedometer buffer in some publications, can be gotten at a gm dealer.
Car: 87 IROC
Engine: 5.3L
You in a bad mood or something?
Interference fit usually means that it's pressed on. Good to know that it comes off easy though.
Yeah, but it's $105 depending on where you get it from. And there is probably a few hundred thousand out there in a wrecking yards or in someones garage that aren't being used.
Thanks for the info. I didn't know that already.
LT1Formula
20
Nov 14, 2015 12:02 AM
