WTB: 85-89 L98 TPI Harness/ECU/PROM !!
Old May 8, 2008 | 04:13 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
Swapping a L98 TPI into my 2.8 RS.. i need the harness, and PROM.. if the computer is the same, if it isnt i need the ECM.. if someone knows how i can check to see if i can just swap the PROM and use a new harness, let me know!
John
Old May 8, 2008 | 08:13 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: WTB: 85-89 L98 TPI Harness/ECU/PROM !!
if your car is a 2.8 you will also need the ecm
Old May 8, 2008 | 08:14 PM
Engine: THREEFIDDY!
thanks for the heads up..
bumppp on an ECM and Harness!
Old May 9, 2008 | 08:08 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
John
PM sent
Old May 10, 2008 | 05:24 PM
carlos_garcia7's Avatar
Want a title? Post!
I have a harness from an 88 IROC Z It is a 350 TPI, i also have the computer with prom, it does not have the Vats and i have only replaced the MAF pigtail, other than that it is in good shape let me know. Im not sure how much, but make me a resonable offer, ill even give you the MAF Sensor (carlos_garcia7@hotmail.com)
Old May 12, 2008 | 06:01 PM
my82roc's Avatar
Car: 89 Iroc Convertible
PM Sent
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
