WTB: Transmission Conversion parts
I am doing a V8/transmission swap
I need?
A V8 bell housing for T5
All the hydraulic Clutch stuff
A flywheel for the V8
The difficult one
I am looking for a clutch/pressure plate for a T5 that came out of a V6 camaro I believe that is the 10 spline.
Wade
I need?
The difficult one
Wade
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: WTB: Transmission Conversion parts
I have a very good condition 10 or 14 spline disc by Centerforce. I"ll double check the spline count tonight. I accidentally purchased it when I should have been looking for a standard V8 spline count. The pressure plate won't matter. It will work with both V8 and V6 discs as long as they are 10.5" F-body clutch set-ups.
Are you just doing a transmission swap or are you doing a V6 to V8 swap as well? I have a large number of parts that you may be interested in if you are doing a V6 to V8 motor swap.
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
I have a t-5 master and slave setup. Worked fine when I drove car home. Could use some fresh fluid and a good bleeding. Its in my way, will get rid of it cheap.
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
