WTB: 3.23+ posi rear w/ PBR & prop valve
Old Oct 31, 2008 | 12:23 PM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
I have decided to sell (or trade) my LS1 rear disc setup and instead locate a 3.23 (or possibly numerically higher) posi rear end w/ PBR discs to install instead. I would still need the prop valve, but it'll be easier to get it all from one person. Located in CT, so closer the better.
Jeff
Last edited by Jeffrey Fontaine; Oct 31, 2008 at 12:24 PM. Reason: Added possibility of trade
Old Nov 14, 2008 | 08:57 AM
85 lg4's Avatar
Car: 89 TA
Engine: Fast !!
Transmission: slipinslide auto
Re: WTB: 3.23+ posi rear w/ PBR & prop valve
I have e torsen diff and 3.23 ring pinion,bearing and all out of my car GM stuff removed at 80 miles(yes less 80 not 80k) for a pro and 3.73's I have had these in a box in my garage for 6 years I will never use them. $150.00 shipped. This stuff is perfect still had the painted assembly marks. If you dried the oild off it would look 100% new I oiled them up good so they would not rust I just checked them over no one spot on them perfect !
I take paypal or M.O if your close top in and pick them up for $125.00
Old Nov 14, 2008 | 10:01 AM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Jeff
$300 3:23 pbr rear
Old Nov 17, 2008 | 07:32 PM
Car: 1992 Z/28
Thanks! I'm trying to sell an LS1 rear disc swap setup and a set of 25th anniv. rims, so when one does, I'll drop you a line.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
