WTT Tpi for my carb
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
WTT Tpi for my carb
i am looking for a tpi, complete, bolts, thermo, fuel rails, plenum, base, runners, throttle bracket, everything i need to change over
i have the wiring and ecm, and i just need the bolt on assembly
what i offer:
i have a edelbrock performer rpm enderuashine, i think its a 600-650, manual choke, clean, i never used it, but it was on a car for maybee 2000 miles straight road trip, and they changed to holley, it was new when they got it.
custom made spacer plate, about 1 inch, 12 pt. bolts, chrome thermo housing, new thermostat, all hardware included
holley single plane intake, high rise, but still low profile
this setup will fit under a stock hood without the spacer, with you need a rise, either a cowl or scoop, whatever you like
custom made throttle cable
all you need is the TV bracket, its about 30 bucks from summit
i will give you my compete setup for your compete setup
i dont need the plenum extender if that is a problem
less dents the better, but ill take what i can get
ill pay shipping for my setup and may pitch in to ship your setup
i dont have cash to throw in, but i have parts to offer as well
let me know what you have, and what you want to do
thanks
keith
what i offer:
thanks
keith
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: WTT Tpi for my carb
If you ever sell that set up, I have a TPI set up complete except for ECM, Distributer and fuel pump, for 300 shipped.
does anyone have a later tpi wireing harness and ecu, the one that doesent use MAF, what tpi wise has to change, the base?
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
