NTB/WTB Chevy 350 4 bolt block, heads optional
Old Jan 25, 2009 | 06:01 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Hey guys, after paying some attention to the frequency of me adding fluids I've found myself needing a new motor.
I need a 350 4 bolt block, if heads are included that's fine, but I'm not really after them since I can still use the 305 ones. I will rebuild the block, so I'm not worried about minors issues as long as I won't be buying a lemon(no cracks allowed). If anyone has a line on one I'd love to hear about it.
I live in western KY area, so if I can I'll drive to pick it up, or pay for shipping if it's reasonable.
Old Jan 26, 2009 | 08:41 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: NTB/WTB Chevy 350 4 bolt block, heads optional
I have an older GM crate 350 that developed a light rod knock due to thinned oil. It's a 4 bolt, has heads still and I'm in central Ohio.
Old Jan 28, 2009 | 01:14 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
I have a 69 camaro 4 bolt main 010 block(had extra zinc and nickel so the block is stronger) its got a .40 over bore. 300 bucks plus shipping for the short block.(need to replace two pistons, they kissed a valve and broke no damage to inside of cylinders but I have to rebuild the heads(im keeping them anyway). Before this happened the motor had 2000 miles on a rebuild the cyl walls look like glass! Im in jersey so add shipping to 300.
Old Jan 28, 2009 | 03:35 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
PM sent.
Old Jan 31, 2009 | 07:30 AM
mos68x's Avatar
Do you know how the cylinders look? How much total(including crate) with shipping to 42211?
My stock 87+ 305 heads will still fit the block...right?? Since I'd have to replace (2?) pistons, which pistons did you have in it? Do you think the bearings are still good? How much total(including crate) with shipping to 42211?
Old Jan 31, 2009 | 09:49 AM
jersyboyy's Avatar
Car: 85 Camaro
My stock 87+ 305 heads will still fit the block...right?? Since I'd have to replace (2?) pistons, which pistons did you have in it? Do you think the bearings are still good? How much total(including crate) with shipping to 42211?[/quote]
305 heads would fit on this block and would make it have higher compression. It has 4 valve relief flat top pistons.
85 dollars from summit. Set of 8 replacement pistons.
Bearings are still good it was running up until the day I pulled the heads a(just didnt know it had 2 bad pistons untill that day, and no weird noises or anything)
I think crate shipping fo rthe short block would be around 200-250 let me know Im willing to drive up to 2 hours away as well if you wanna meet up.
Old Feb 3, 2009 | 12:30 AM
nes_t_383's Avatar
pm sent
Old Feb 15, 2009 | 12:52 PM
MartinD's Avatar
In have several rebuildable 350's from 4 barrel engines to tbi engines.I live in south georgia.$150 each
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
355tpipickup
Aug 25, 2015 12:54 AM
NinjaNife
Aug 23, 2015 11:49 AM
