[LA] NEED PARTS FOR A 305...PLEASE HELP
Old Apr 10, 2009 | 10:08 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
i need parts for a rebuilt 305 i have..gonna try and get it up ..all i need is parts for the outside of block..i have exhaust and y pipe already..and wire harness for tbi..have a quadra jet intake and a tbi intake
  1. dist..have a dist but nothing on it..needs parts for it
  2. ecm
  3. sensors
  4. alt.
  5. pulley setup.all i have is the power steering and crank pulley and idle pulley..not worried about a/c or smog
  6. motor mounts for frame..going from 2.8 v6 to 305
  7. also need a v-8 5 speed manual tranny will trade a v-8 700r4 for it
i don't have very much money to buy things if you have them laying around and want to junk them send them my way please...
if you have any parts let me now what all you have..
thanks brad
Old Apr 10, 2009 | 10:46 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: NEED PARTS FOR A 305...PLEASE HELP
  2. ecm
  3. sensors
  4. alt.
thanks brad
i have an entire dist from my 305 tbi that i just pulled. what sensors do you need? and i also have the ecm.
Old Apr 10, 2009 | 11:10 PM
snowman383's Avatar
Engine: 350 crate
i have a knock sensor but it broke the connection..basically i need all motor sensors,,water temp oil pressure,, knock,and so on.the dist and ecm would be great...can't afford a whole lot... been out of work for 8 months.and living off of wife's check,not very much for work around these parts of the woods..time to go back driving 18-wheeler i guess..
Old Apr 11, 2009 | 12:43 AM
snowman383's Avatar
Engine: 350 crate
still needing some parts.... please help out
Old Apr 11, 2009 | 04:33 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I have a 305 knock sensor TBI. Make and offer
Old Apr 11, 2009 | 11:27 AM
snowman383's Avatar
Engine: 350 crate
found a knock sensor in my tool box..thanks for the offer..
Old Apr 12, 2009 | 01:47 AM
snowman383's Avatar
Engine: 350 crate
STILL NEED A FEW PARTS..ANY HELP WOULD BE GREAT
Old Apr 12, 2009 | 09:42 AM
Engine: Vortec 357
name your price for the dist. and ecm. I have aftermarket water and oil pressure sensors but wont work for you. I also have 1 good motor mount on passenger side. Name your price .
Old Apr 12, 2009 | 11:51 AM
snowman383's Avatar
Engine: 350 crate
pm sent
Old Apr 12, 2009 | 08:05 PM
snowman383's Avatar
Engine: 350 crate
will you do 60 shipped
also need serp setup..i have crank pulley water pump and power steering already..i need alt and bracket..not running air or smog on it..what else do i need on pulley setup
Old Apr 13, 2009 | 12:09 AM
snowman383's Avatar
Engine: 350 crate
Crane Cams 6000-6302
Brand:Crane Cams Product Line:Crane HI-6S CD Ignition and Coil Kits Part Type:Ignition Box and Coil Kits Part Number: CRN-6000-6302 Circuitry: Digital Rev Limiter: Yes Ignition Box Output: Inductive Timing Retard: One-stage CD Voltage Output to Coil: 450 V Minimum Operating Voltage: 6 V Maximum Operating Voltage: 18 V Current Draw: 5 amps at 7,000 rpm Spark Output (millijoules): 135 Millijoules Length (in): 5.500 in. Height (in): 1.500 in. Width (in): 3.000 in. Ignition Box Color: Black Coil Included: Yes Coil Style: E-core Coil Internal Construction: Epoxy Maximum Voltage: 45,000 V Mounting Bracket Included: No Coil Wire Included: No Coil Shape: Square Coil Color: Black CARB EO Number: D-225-59 Quantity: Sold as a kit. Notes: The coil in this kit does not include a mounting bracket. It is designed to mount using the factory coil mounting bracket. Will not fit LT-1 applications. Ignition System, HI-6S Inductive with Coil, GM, Kit
Up to 70 percent more spark energy.
Crane's HI-6S ignition and coil kits will give you up to 70 percent more spark-gap energy than stock ignitions. Designed for street and racing use, they come with Crane's "Plug-n-Go" universal harness to cover most installations, with optional harnesses available separately. With a max output of 8,000 rpm (can be extended to 10,000 rpm on 4-cylinder engines) for up to 9.5:1 compression engines, you'll be sure to feel the improvement. Their built-in rev limiter automatically drops cylinders in firing order to prevent fuel loading, and is adjustable from 3,100-9,900 rpm in 100-rpm increments, without any chips. The optional 0-20 degree adjustable timing retard and MAP sensor make a great combination for nitrous and turbo applications. They have a soft urethane encapsulation that seals against moisture, dirt, dust, vibration, and heat, and an anodized heat-sink shell for reliability. Crane designed them to be points or module-triggered for 4, 6, and 8-cylinder engines with distributors.
[quote]will this bypass the ecm to run motor on my 305[/quote]
Old Apr 14, 2009 | 09:31 PM
snowman383's Avatar
Engine: 350 crate
still need some parts please..cant afford new right now..on a limited budget
Old Apr 14, 2009 | 09:46 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
i have a complete 305 tbi on my engine stand with all the parts lmk in a pm what you need thanks
Old Apr 14, 2009 | 10:10 PM
snowman383's Avatar
Engine: 350 crate
pm sent
Old Apr 23, 2009 | 09:42 PM
snowman383's Avatar
Engine: 350 crate
got my 305 in..now i still need to get some parts..need complete dist,sensors,tbi, i have everything else..help out if you can..this is all i need to get my car on the road after it sitting for 10 yrs..I'm cant afford to buy anything sense the wife's tranny went out in her car..so i am completely broke..help out if you can
Old Apr 23, 2009 | 10:53 PM
snowman383's Avatar
Engine: 350 crate
please help me out need to get car going
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
