In Drastic Need of GOOD Heads (AFR, Trickflow)
Old Jun 10, 2009 | 09:29 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
I need heads for my new 355 with High flow TPI intake. I have cash adn am ready to buy. Please contact me with what you have!
Josh
Old Jun 11, 2009 | 08:14 PM
transformula87's Avatar
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
Re: In Drastic Need of GOOD Heads (AFR, Trickflow)
pm sent.
Let me know.
Old Jun 12, 2009 | 01:01 AM
FireChicken2.8's Avatar
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
Have the Trickflow TFS-K314-500-450 set from summit. Brand new.
Old Jun 14, 2009 | 04:52 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I have a fresh set of Trickflow Twisted Wedge G1s. New valves, valve guides, HD springs, mild pocket porting, cut back valves. Vatted and head surface is decked. Complete with the proper Gold Race rocker arms. Perfect flow for modified TPI set up. $980 plus shipping. Can send photos if interested.
Old Jun 20, 2009 | 08:25 AM
MattVette89's Avatar
Car: 89 Vette
Engine: Built 383 :)
Axle/Gears: 3.07
Try here:
https://www.thirdgen.org/forums/engi...heads-l98.html
Edit - sorry, just saw you already posted there!
Good luck
Old Jun 28, 2009 | 01:01 PM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
Were you still interested in the heads?
You never did post or PM me the information on your car, so I'm not sure what kind of options you have.
Assuming you are running a zero deck motor, with a flat top piston, and you run a .055 comrpessed gasket, I come up with 11.7. The combustion chamber on these heads is more than capable of supporting that compression ratio on pump gas. I would be comfortable dropping to a .045 gasket and coming up with 12:1 if the dynamic compression stayed inline.
Post up some specs on your motor and we can figure out if these heads will work for you or not. Cam specs are pretty important as well.
evilstuie
Jan 9, 2020 08:29 PM
CRFred
Feb 7, 2016 11:39 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
