Need a bell housing and misc parts for a t-5
Old Nov 3, 2009 | 04:31 PM
boysatt's Avatar
Car: 1991 Iroc Camaro
Engine: 350 V8
Transmission: Auto, being converted to manual
I am swapping my 91 camaro 350 V8 to a 5 speed, I have most of the parts but my parts car was a v6. So I need a bell housing, clutch fork, flywheel and maybe a good used clutch.
Mike
boysatt@aol.com
Old Nov 4, 2009 | 04:45 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: Need a bell housing and misc parts for a t-5
PM sent
Old Nov 4, 2009 | 07:15 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
correct me if im wrong, isnt the v-6 t-5 an 10 input spline, a v8 needs a 26 spline input?
edit:i was wrong about the v6 10 spline, its a 14 spline
Old Nov 4, 2009 | 09:08 AM
boysatt's Avatar
Engine: 350 V8
Actually i guess your right, guess I need to rethink things
Old Nov 4, 2009 | 09:15 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Okay the parts car. You can take the slave cylinder, the pedals out. they should be the same. And for being a 10 spline if this is correct. idk never messed with v6's couldn't he just take the driveshaft out of the v6 to put it on his car with no modification. Please correct me if i am wrong. All he would need then is just the flywheel, bellhousing, I would go new on and get a complete clutch kit. I got one for 116 bucks. Autozone has them or any parts store can help you get it. It comes with the alignment tool, pilot bushing, throwout bearing, clutch, pressure plate. You can even get the bellhousing bought with the clutch kit little expensive. But i would go used on it. and the flywheel can be used as well just make sure its been machined surfaced it will cost 30 dollars so keep that in mind if someone wants big money. You can buy a new flywheel for 150 bucks depending what you want.
Old Nov 4, 2009 | 09:21 AM
boysatt's Avatar
Engine: 350 V8
Thats what I was thinking until I just found some info on the tranny. v6 trans has a longer input shaft.
http://www.hamiltonintakes.com/produ...formation.html
Old Nov 4, 2009 | 09:25 AM
berlin305's Avatar
Well nice to know information about that. I am currently in a swap but not in the situation that your in i took parts off a firebird v8. but hmm. But even with the input shaft longer wouldn't the driveshaft be shorter?
Old Nov 4, 2009 | 09:27 AM
berlin305's Avatar
With reading that so you would need a S10 bellhousing?
Old Nov 4, 2009 | 04:40 PM
I was talking about the input 14 spline to meet to the engine/clutch is for a v-6. IF thats what he gots, a V8 fbody has 26 spline, mustangs have a 10 spline input . im new and learning still. but check out this link to make sure. https://www.thirdgen.org/forums/tran...ything-we.html
Old Nov 7, 2009 | 10:09 AM
holeshotkid's Avatar
I have a flywheel for a 1 piece rear main seal. Less than 300 miles on it. $65 shipped. Can email you pics if interested.
Troy
Old Nov 7, 2009 | 10:30 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Having "been there, done that" here is what you need:
You need the bellhousing, clutch fork, and pressure plate from a V8 thirdgen. No other ones will work(the s10 bellhousing does not have the proper "tilt" to it AFAIK)
The throwout bearing is the same between the V8 and V6, but while you have everything apart its best to replace it.
You need a V8 thirdgen flywheel that matches your engine - ie 1 piece RMS or 2 piece RMS. Getting a used one resurfaced only cost me $35 BUT you need a spacer to go between the flywheel and the crankshaft so the clutch travel is correct if you have a hydraulic clutch(which you should have)
The input shaft for a V6 T5 does have 14 splines while the V8 T5 has 26 splines on the input shaft. To use a V6 T5 you have to use a clutch disc from an 82 GMC S15 with the 2.8V6. P/N at Autozone is CP4201
The input shaft on a V6 T5 is only about 1/4" longer than on a V8 T5. I found this out the hard way when I cracked the bellhousing trying to force everything together. I took my angle grinder with a cutoff wheel and cut off the end of the input shaft. Then I used a grinding wheel to put the chamfer back on the edge of the input shaft. Just put the trans in neutral and spin the shaft while holding the grinder against it. Its not an important step, but it helps everything slide together easier.
P.S. - all this is covered in the T5 FAQ linked above
Old Nov 11, 2009 | 07:06 PM
super_b_car_guy's Avatar
Car: 83 z28
Engine: 305 sbc, and 400 sbc
Transmission: 700r4, and th350
Axle/Gears: currie 9" with 4.30 posi
i got a lakewood bellhousing and scatter shield if interested.
Old Nov 15, 2009 | 02:00 PM
bigfish1047's Avatar
Car: 1984 Berlinetta
Engine: 355
Transmission: 350
Axle/Gears: 4.30:1
Their is a reason GM never put a T5 behind a 350, good luck
WOW there must have been a glitch since I lost a bunch of post since here last !!
Old Nov 25, 2009 | 06:22 PM
mmiglass's Avatar
Want a title? Post!
Car: 1984 trans am
Engine: 5.0 ho
Transmission: 5 speed
Axle/Gears: good
Mike
boysatt@aol.com
1984 Trans am
Buket seats black and grey power river side every thing works look nice 80.00 bucks for the set of two
Rear seat ok just a little sun fad on top black and grey 45.00
305 350 starter like new with life time warranty just use my phone # at auto zone if you ever need it replaced 35.00
New tires on after market wheels size 15inch 250.00 for the set of 4
Holly for barrel carb with electric chock works great 150.00 will also fit 350 motor
Stock carb works good will also fit 350 motor 95.00
edelbrock intake will also fit 350 chevy motor in great shape 85.00
stock intake 25.00
flow master muffler 35.00 just muffler
posi read end in great shape 175.00 obo
5 speed trans mission almost new stick shift 375.00 obo
Bell housing for stick 55.00
Clutch like new 75.00
Clutch slave like new 35.00
Chrome valve covers ok shape 25.00
edelbrock water pump been rebult and test works great 30.00 polished needs to be redone to make it shine
accel distributor and cap works great 75.00 obo
rear hatch back with glass and defrost 75.00 obo white
rear hatch back with glass no defrost 50.00 obo red
driver side door with glass and power everthing works 150.00 obo white
pass side door power with glass works 150.00 obo white
hood with rams air small dent the size of a quarter 175.00 obo white
front brakes disc calipers and all 175.00 obo
rear dics brake calipers and all 150.00
trans am glove box 35.00 in good shape
305 eninge runs but smokes need rebult 250.00 obo
Fly wheel redone 45.00
Front side feanders in good shape just needs paint 175.00 each obo
Headlight with motor work good both for 125.00 or 75.00 each
Radiator works good no leaks 75.00 obo
Fan works 45.00 obo
And lots more let me know what you need I have it 951 235 0621 mike
mmiGlass@aol.com any thing you need let me know iwe can always work on the price in cali zip 92548 trans is almost new same for clutch fly wheel redone and new clutch slave
LT1Formula
20
Nov 14, 2015 12:02 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 5, 2015 11:57 PM
