[IL] Vortecs
Old Dec 27, 2009 | 08:38 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Vortecs
Looking for a set of vortecs, prefer some that already have the spring mod done so I can run a .461" lift cam. Also need a set of self aligning rockers and center bolt valve covers.
Old Dec 30, 2009 | 09:43 PM
IAGTA's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
Re: Vortecs
I've got a set of brand new 062 casting Vortec's that are unmodified. I bought them for my L98 but decided to keep stock parts. I paid $450 for them and that's my asking price. They are stock so that may not fit your needs but the cheapest I've seen them new is $310 apiece.
Old Dec 31, 2009 | 01:12 PM
kizmaro89's Avatar
Car: 89 Camaro RS
Engine: LM7
Re: Vortecs
I've got a set with intake i bought from scoggin dickey a few years ago. I only used them for about 1000-2000 mi. before starting an lsx swap. Also have the valve covers and rockers. Asking $650. obo
http://www.sdpc2000.com/details/scog...ter/sd8060arpm
"This kit features our upgraded Vortec heads which have been modified to accept our high performance Z28 valve springs with lightweight LT4 retainers. This produces a high reving cylinder head that can handle up to 0.525" lift hydraulic camshafts. An Edelbrock Vortec Performer RPM intake manifold is matched with this kit for optimum performanc"
Old Jan 1, 2010 | 06:25 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Re: Vortecs
I already had to go ahead and purchase new heads, intake, rockers.... Have over 800.00 in it so far and still not done buying parts....
Any idea what kind of HP you were making? What cam were you running with that setup, and where in MO are you located?
Old Jan 1, 2010 | 02:19 PM
kizmaro89's Avatar
Car: 89 Camaro RS
Engine: LM7
Re: Vortecs
I had them on a 327 with Lunati Cam (Advertised Duration 262/268, Lift .468/.489). Not sure on the HP because i never had it on a dyno. I copied the setup from some other 327 builds i found on and their setups made between 350-375 with that cam. I'm in cental MO 230mi west of STL about 20mi off I-70
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
