Fan shroud ?
Old Jan 19, 2010 | 04:39 PM
brian schuetta's Avatar
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
Fan shroud ?
Went to put my electric fans back in after engine change and the part that bolts to the radiator support that connects to the fans broke in three places. Had dual fans in car. Got the whole set off e-bay long time ago. Anybody got this part my fans are good. Thanks.
Old Jan 21, 2010 | 06:25 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
Re: Fan shroud ?
the upper mount or lower mount
Old Jan 21, 2010 | 03:10 PM
Engine: 383
Transmission: th350
Re: Fan shroud ?
The upper one. I found out its called a radiator support cover, I think. The top of the electric fans bolt to it. Sent e-mail to Classic Industries but haven't heard back yet. Can't find type of donor car needed in town yet. Only go to two yards here. Since I'm white they try to rip you off down here. Had somebody ask $20 plus for four trans crossmember bolts if I took them off myself.
Old Jan 21, 2010 | 05:52 PM
Transmission: auto
Re: Fan shroud ?
i can help with the upper fan shroud and the 4 trans bolts with the big washers if those are still needed
Old Jan 21, 2010 | 09:08 PM
Engine: 383
Transmission: th350
Re: Fan shroud ?
Cool, how you want to do it and how much? Got the crossmember bolts from a u-pull-it place that just opened. They bought an existing yard.
Old Jan 22, 2010 | 05:27 AM
Transmission: auto
Re: Fan shroud ?
here is my e-mail address wtg3575@aol.com so we can work something out
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
