[AL] WTB: 4 disc prop valve, '91 RS
Old Mar 16, 2010 | 01:47 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I'm looking for a 4 wheel disc prop valve to fit a 91 RS. I switched from drum to disc and the factory valve isn't cutting it. I would prefer to find a good used one before spending the money for a new one.
Old Mar 16, 2010 | 01:55 PM
SMOKIN Z's Avatar
Car: 1991 z28 vert/91 rs vert/85 TA vert
Engine: stock tpi 305/tbi 305/tpi 305
Transmission: 700r4/ 5 speed
Axle/Gears: 4th gen rear in progress/stock
Re: WTB: 4 disc prop valve, '91 RS
I have one from a 1989 formula 350. It had PBR brake calipers in the rear. Let me know if your interested....
Old Mar 16, 2010 | 02:06 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should you be unaware, there are two designs:
1st design: M1.0 tube nut threads (For 1982 - early 1989 applications)
2nd design: M1.5 tube nut threads (Late 1989 through 92)
Also, there's the following, a cheaper alternative than new:
http://www.flynbye.com/catalog/i160.html
JamesC
Old Mar 16, 2010 | 02:16 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
1989 1st design: M1.0 tube nut threads (For 1982 - early 1989 applications)
1989 2nd design: M1.5 tube nut threads (Late 1989)
1990-'92: M1.5 tube nut threads.
JamesC
Hmm I was not aware of the modification kit. I was aware there were 3 diff designs, I did have the years wrong though. Know of anyone who has tried the kit and how hard is it to install?
Old Mar 16, 2010 | 02:27 PM
JamesC's Avatar
As I understand it, there are only two designs. I edited above for the sake of clarity.
You might contact Ed. My guess is that he does the modification in house and sends the valve out, but you might ask on the brake board.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
corey8084
Sep 17, 2015 02:56 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
sandman92084
Sep 12, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
