Want Cam from 87 TPI 305 5spd car
Old Mar 19, 2010 | 07:57 PM
mvp2ceo's Avatar
Car: 87 IROCZ
Transmission: 700R4 shift kit, corvette servo...
Axle/Gears: 26 spline 4.10 mini spool
i have the auto 305 tpi camaro and want the better cam
Old Mar 19, 2010 | 09:57 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Want Cam from 87 TPI 305 5spd car
You might want to verify you have the "small" cam first before you spend the money on a better cam. Not to mention going to all the work to change the cam and only putting in another stock one.
Perhaps an LT1 cam or similar would be better than a stock TPI cam?
Old Mar 20, 2010 | 10:05 AM
goose21's Avatar
Car: 85 Monte Carlo, 93 C1500, 98 Neon
Engine: 355, 4.3L, 2.0 DOHC
Transmission: T5, 4L60E, T350
Axle/Gears: 2.73, 3.42, 3.94
I have a cam from an '87 L98 engine (350 TPI).
Are you interested in it?
Old Mar 22, 2010 | 12:21 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
i just pulled one out of a 91 tpi 305 manual. pm me an offer if that'd work.
Old Mar 22, 2010 | 10:09 PM
mvp2ceo's Avatar
Car: 87 IROCZ
im waiting on a couple responses to find out what is best i will def let u guys know if i need either 1
Old Mar 25, 2010 | 09:04 AM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
get an LT1 cam, or at least an L98 cam, just look at the specs, the LT1 cam is 447/459 lift L98 is 410/420 lift, both with around the same duration, if you find an LT1 cam from a 93 fbody you wont even have to grind the dowel down to fit and it should work ok with the stock MAFS computer just get springs to match, a S10 torque converter and of course headers and a good exhaust and you should have a decent 305, check out some of my threads cause ive found out all this info on these message boards, if you cant find the lt1 cam tho at least get the L98 dont bother with the 305 cam unless its from a 91-92 5sp cause they def had the L98 cam
Old Mar 28, 2010 | 02:43 PM
mvp2ceo's Avatar
Car: 87 IROCZ
thanks i found lt1 cam on ebay for $25 and lt1 springs for $79 jus waiting now....hope everything works...........im already running 24lb injectors adjustable regulator gutted maf ported heads and intake 1.6 rockers 20-22 stall built 700 410 gears and mini spool so i hope the cam goes good with all this
jhawkeye
May 25, 2022 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
drathaar907
Aug 10, 2015 07:44 AM
drathaar907
Aug 6, 2015 04:20 PM
