[CO] WTB:SBC HYD. ROLLER CAM COMP OR LUNATI
Old Aug 26, 2010 | 10:25 PM
chrisr0315's Avatar
Car: Hot Wheels
Engine: Stroker 383
LOOKING 350SBC HYD. ROLLER FOR RETRFO FIT MUST HAVE IRON DIST GEAR . 220-230 INT , 230- 240 EXH. @ .050 .520 + LIFT EXTREME, XFI THUMPER , MAGNUM , VOODOO , OR SIMILAR . MAY CONSIDER PART TRADE ON MY HEADS FOR SALE .
HELP OUT AN HP JUNKIE
Chris
Old Aug 27, 2010 | 09:52 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: WTB:SBC HYD. ROLLER CAM COMP OR LUNATI
Chris,
Don't restrict yourself. With this very inexpensive kit from Lingenfelter, you can use any SBC roller cam...not just retrofit. That really opens up your selection.
http://www.lingenfelter.com/mm5/merc...egory_Code=C30
You will have to use a later model timing set from a factory roller motor. I have used this kit on several occasions. It works great.
Old Aug 27, 2010 | 12:28 PM
chrisr0315's Avatar
Car: Hot Wheels
Engine: Stroker 383
hey Wesliva
yea ,thanks . I have the kit w/ spring loaded button . Im not limiting myself, it's just I would like to find either a Lunati Voodoo , or Comp Cams Thumper . I did say or similar tho . A bumpy Lingen. stick would match my headers . so Im open but dont want factory
Thanks Again
Chris
Old Aug 27, 2010 | 03:33 PM
wesilva's Avatar
Transmission: 200R4
Ah...ok. I thought you were restricting yourself to retrofit cams only. With the Lingerfelter adapter kit, your selection is much greater.
Old Aug 27, 2010 | 04:51 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
PM'd you Chris
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
john204481
Sep 7, 2015 03:22 PM
