Stock '87 disc brake brackets
Old Aug 29, 2010 | 08:58 PM
SKFengineer's Avatar
Car: '87 IROC (TPI 350), '01 Corvette, '
Engine: '90 Corvette 350, blueprinted and b
Transmission: 700 R-4, with stage 2 shift kit
Some how the bracket that bolts between my axle tube and the caliper is bent causing odd brake pad wear... Things are working now but I was hoping to replace the bracket before state inspection. The car is an '87 IROC with the 10-bolt rear... not the aussie rear. Also if anyone has an idea of a vendor that would sell them I'm all ears.
Old Sep 23, 2010 | 04:09 AM
MPIpowered4x4's Avatar
Re: Stock '87 disc brake brackets
Pm'ed
Old Sep 23, 2010 | 02:36 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Are the calipers on your rear end the iron ones cause if so I have a set at my shop Im willing to sell
Old Sep 23, 2010 | 02:55 PM
Yes they are the iron ones... They are the "earlier" calipers I know that there was a change after '88 and mine are from '87.
Let me know if it sounds like you have the right parts. Thanks
Old Sep 23, 2010 | 04:32 PM
6SIX6's Avatar
Car: 89 IROC
They are the right ones then as I got a set off a TGO member and then I bought a new rear for the gears and they had a set on there so now I have an extra set. Let me know if you want them for sure as I will have to bring them down from my shop.
Old Sep 23, 2010 | 07:23 PM
IrocZ'85's Avatar
Car: '85 IrocZ
I'm actually having the same problem, the bracket caused my caliper bolts to go in at a weird angle, and my rear brake makes a clicking noise when i get on it. Now i know what to look for also, thanks!
Old Sep 24, 2010 | 09:52 AM
I'm going to send you a PM with my E-mail.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
