[MS] LT1 Rear Brakes
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
LT1 Rear Brakes
I'm looking for a pair of '93-'97 F-body rear brake calipers and brackets. I've already got a set that are no good; so I need to know that your are in good working order.
Thanks.
Thanks.
Re: LT1 Rear Brakes
I dont know if you need them, but i have new brake pads for them.
https://www.thirdgen.org/forums/exte...-metallic.html
just incase you do!
just incase you do!
Re: LT1 Rear Brakes
Thanks, but pads should be easy enough to pick up locally. I've got to find the calipers first.
Re: LT1 Rear Brakes
Thanks, but I ended up buying some remans from Advance last night. They're supposed to be in today. Had them for ~$55 a piece plus core if anyone else has trouble finding any. Just have to make sure they come with the brackets when they get here.
Re: LT1 Rear Brakes
MPI, PM sent.
1992 Trans Am
Aug 8, 2015 08:16 PM
